Help: Code for Nixie Stock Ticker
I'm working on a project that uses an arduino to create a stock ticker on 6 Nixie tubes. The stock price is being scrapes and sent to the arduino via pi. I have code for a four tube display. Was wondering if anyone could help me transform that into a six tube display. Any help would be greatly appreciated. Here's the initial code.
//this is based on the Arduinix 6-digit clock code. It includes code to drive
//the Adafruit I2C 128x32 OLED display for debug purposes.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 14
Adafruit_SSD1306 display(OLED_RESET);
// SN74141 (1)
int ledPin_0_a = 2;
int ledPin_0_b = 3;
int ledPin_0_c = 4;
int ledPin_0_d = 5;
// SN74141 (2)
int ledPin_1_a = 6;
int ledPin_1_b = 7;
int ledPin_1_c = 8;
int ledPin_1_d = 9;
// anode pins
int ledPin_a_1 = 10;
int ledPin_a_2 = 11;
int ledPin_a_3 = 12;
pinMode(ledPin_0_a, OUTPUT);
pinMode(ledPin_0_b, OUTPUT);
pinMode(ledPin_0_c, OUTPUT);
pinMode(ledPin_0_d, OUTPUT);
pinMode(ledPin_1_a, OUTPUT);
pinMode(ledPin_1_b, OUTPUT);
pinMode(ledPin_1_c, OUTPUT);
pinMode(ledPin_1_d, OUTPUT);
pinMode(ledPin_a_1, OUTPUT);
pinMode(ledPin_a_2, OUTPUT);
pinMode(ledPin_a_3, OUTPUT);
Serial.begin(19200);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C...
// ...for the 128x32 OLED display
display.clearDisplay(); // set up I2C display
display.setTextSize(2);
display.setTextColor(WHITE);
void DisplayNumberSet( int anod, int num1, int num2 )
int anodPin;
int a,b,c,d;
// set defaults to blank display
a=1;
b=1;
c=1;
d=1;
anodPin = ledPin_a_1; // default on first anode.
// Select what anod to fire.
switch( anod )
case 0:
case 1:
anodPin = ledPin_a_2;
case 2:
anodPin = ledPin_a_3;
// Load the a,b,c,d.. to send to the SN74141 IC (1)
switch( num1 )
case 0:
a=0;
b=0;
c=0;
d=0;
case 1:
a=1;
b=0;
c=0;
d=0;
case 2:
a=0;
b=1;
c=0;
d=0;
case 3:
a=1;
b=1;
c=0;
d=0;
case 4:
a=0;
b=0;
c=1;
d=0;
case 5:
a=1;
b=0;
c=1;
d=0;
case 6:
a=0;
b=1;
c=1;
d=0;
case 7:
a=1;
b=1;
c=1;
d=0;
case 8:
a=0;
b=0;
c=0;
d=1;
case 9:
a=1;
b=0;
c=0;
d=1;
case 10:
a=1;
b=1;
c=1;
d=1;
// Write to output pins.
digitalWrite(ledPin_0_d, d);
digitalWrite(ledPin_0_c, c);
digitalWrite(ledPin_0_b, b);
digitalWrite(ledPin_0_a, a);
// Load the a,b,c,d.. to send to the SN74141 IC (2)
switch( num2 )
case 0:
a=0;
b=0;
c=0;
d=0;
case 1:
a=1;
b=0;
c=0;
d=0;
case 2:
a=0;
b=1;
c=0;
d=0;
case 3:
a=1;
b=1;
c=0;
d=0;
case 4:
a=0;
b=0;
c=1;
d=0;
case 5:
a=1;
b=0;
c=1;
d=0;
case 6:
a=0;
b=1;
c=1;
d=0;
case 7:
a=1;
b=1;
c=1;
d=0;
case 8:
a=0;
b=0;
c=0;
d=1;
case 9:
a=1;
b=0;
c=0;
d=1;
case 10:
a=1;
b=1;
c=1;
d=1;
digitalWrite(ledPin_1_d, d);
digitalWrite(ledPin_1_c, c);
digitalWrite(ledPin_1_b, b);
digitalWrite(ledPin_1_a, a);
// Turn on this anode.
digitalWrite(anodPin, HIGH);
// Delay
// NOTE: With the difference in Nixie bulbs you may have to change
// this delay to set the update speed of the bulbs. If you
// dont wait long enough the bulb will be dim or not light at all
// you want to set this delay just right so that you have
// nice bright output yet quick enough so that you can multiplex with
// more bulbs.
delay(2);
// Shut off this anode.
digitalWrite(anodPin, LOW);
// DisplayNumberString
// Use: passing an array that is 8 elements long will display numbers
// on a 6 nixie bulb setup.
void DisplayNumberString( int* array )
// bank 1 (bulb 0,3)
DisplayNumberSet(0,array[0],array[3]);
// bank 2 (bulb 1,4)
DisplayNumberSet(1,array[1],array[4]);
// bank 3 (bulb 2,5)
DisplayNumberSet(2,array[2],array[5]);
int NumberArray[6]={10,10,10,10,10,10};
const int MaxChars = 4;
char strValue[MaxChars+1];
int index = 0;
int stock_price = 0;
int d3, d2, d1, d0 = 0;
if (Serial.available())
display.clearDisplay(); //clear I2C display
char ch = Serial.read(); //read char data from RPi via USB serial cable
if (ch > '9')
Serial.println("'A' received"); // received command to blank display
NumberArray[6]=(10,10,10,10,10,10); // '10' blanks a digit
DisplayNumberString(NumberArray);
if (index < MaxChars && ch >= '0' && ch <= '9')
strValue[index++] = ch; //build 4-digit string
strValue[index] = 0;
stock_price=atoi(strValue); //convert ascii to integer
index = 0; //reset index for next time
// Serial.print("the stock price is "); //print to debug console
// Serial.println(stock_price);
d3 = stock_price % 10; // use modulo math to separate integer into indiv. digits
d2 = (stock_price / 10) % 10;
d1 = ((stock_price / 10) / 10) % 10;
d0 = (((stock_price / 10) / 10) / 10) % 10;
display.setCursor(0,18); // print stuff to OLED display (was used for debug)
display.println(stock_price);
display.display(); // this actually prints what was just set up to OLED
NumberArray[2] = d0; // print each digit to a tube (ordering depends on tube board)
NumberArray[3] = d1;
NumberArray[1] = d2;
NumberArray[5] = d3; // MSB
Right, first things first.
Go and read the instructions, then go back and modify your post to mark up the code as such so we can examine it comfortably and reliably.
