[Help] Code only lights upto 40 LEDs in strip
Hello all, I have a code below that works fine however it only lights up to 40 LEDs in the strip. I would like to increase this to 112 but I do not see where to input this. Can anyone give me a hand with this?
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit... if you must, connect GND first.
  strip.begin();
  strip.show(); // initialize all pixels to "off"
  brighten();
  darken();
// 0 to 255
void brighten() {
  uint16_t i, j;
  for (j = 45; j < 255; j++) {
    for (i = 0; i < strip.numPixels(); i++) {
      strip.setPixelColor(i, j, j, j);
    strip.show();
    delay(10);
  //delay(1500);
// 255 to 0
void darken() {
  uint16_t i, j;
  for (j = 255; j > 45; j--) {
    strip.show();
    delay(10);
    Serial.println(j);
  delay(1500);
dawickid1:
Do you think these two might be connected?
You appear to have defined only 12 pixels - somewhat surprising that 40 LEDs do light unless perhaps you are using a 12 V strip with three LEDs per pixel.
