Hi, im trying to code a button to control a servo motor but I'm running into the issue that I'm needing to hold down the button to stop the servo motor from rotating rather than having it so if I press it once, it registers that the button state is HIGH and stops the motor without having to hold it down.
Have a look at the state change detection tutorial.. It shows how to detect the state transitions as opposed to the state levels.
anjaligarg1023:
While you're doing this:
groundFungus:
... change things to the better practice of press meaning low. Wire the button to ground from the pin, pinMode to enable internal pullups, and change the code to look for a low.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. ![]()
