Help Coding a Direct Drive LED Matrix
Hi all,
I running a Mega 2560, to run a 16x16 LED Matrix. Transistors control each row and column, and there are 100k resistors to limit current to the board. Here’s a schematic. http://i.imgur.com/nhjtxMx.png I was hoping to Direct Drive the matrix as seen here.http://playground.arduino.cc/Main/DirectDriveLEDMatrix After Playing around with it for a bit, I managed to make the letters scroll correctly, but only on the bottom 15 rows, and the brightness isn’t good enough. The letters are also upside down. I believe the issue is with the int pins[55] portion. Removing or adding pins makes the matrix not work at all. Here’s the code.
[Here's the Code]
#include <FrequencyTimer2.h>
#define SPACE { \
    {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}, \
    {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ,0}, \
#define H { \
  {1, 1, 1, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0}, \
  {1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0}, \
#define I { \
  {0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}, \
byte col = 0;
byte leds[16][16];
int pins[55]= {-1, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21,
22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34,35,36,37,38,39,40,41,42,43,44,45,46,47,
48,49,50,51,52,53,54};
int cols[16] = {pins[23], pins[25], pins[27], pins[29], pins[31], pins[33], pins[35], pins[37],
                pins[39], pins[41], pins[43], pins[45], pins[47], pins[49], pins[51], pins[53]};
int rows[16] = {pins[22], pins[24], pins[26], pins[28], pins[30], pins[32], pins[34], pins[36],
                pins[38], pins[40], pins[42], pins[44], pins[46], pins[48], pins[50], pins[52]};
const int numPatterns = 3;
byte patterns[numPatterns][16][16] = {H,I,SPACE};
int pattern = 0;
  for (int i = 1; i<= 32; i++) {
    pinMode(pins[i], OUTPUT);
  for (int i = 1; i <= 32; i++) {
    digitalWrite (cols[i - 1], LOW);
    digitalWrite (rows[i - 1], LOW);
  clearLeds();
  FrequencyTimer2::disable();
  FrequencyTimer2::setPeriod(2000);
  FrequencyTimer2::setOnOverflow(display);
  setPattern(pattern);
  pattern = ++pattern % numPatterns;
  slidePattern(pattern, 60);
void clearLeds() {
  for (int i = 0; i < 16; i++){
    for (int j = 0; j < 16; j++){
      leds[i][j] = 0;
void setPattern(int pattern) {
  for (int i = 0; i < 16; i++) {
    for (int j = 0; j < 16; j++) {
      leds[i][j] = patterns[pattern][i][j];
void slidePattern(int Pattern, int del) {
  for (int l = 0; l < 16; l++) {
    for (int i = 0; i <15; i++) {
        leds[j][i] = leds[j][i+1];
   for (int j = 0; j < 15; j++) {
     leds[j][15] = patterns[pattern][j][0 + l];
    delay(del);
void display() {
  digitalWrite(cols[col], LOW);
  col++;
  if (col == 16) {
    col = 0;
  for (int row = 0; row < 16; row++) {
    if (leds[col][15 - row] == 1) {
      digitalWrite(rows[row], HIGH);
    else {
       digitalWrite(rows[row], LOW);
  digitalWrite(cols[col], HIGH);
[/Here's the Code]
Any help is appreciated. Thanks
No there is nothing to limit the current through the LEDs. Using common emitters circuit to drive the rows is silly, you will never get a voltage of greater than 4.3V. You need a PNP top level switch.
Bad tutorial that exceeds current limits on the arduino.
Just the way you wired it up / defined the arrays.
Any explanation for the lack of brightness? It seems to predictably fade after the first 5 rows?
Disregard that last post. The issue was in the setup portion of the code, working fine now. Thanks for your help.
