Help coding in arduino
Hi, I am trying to figure out some code for my project. I currently have a working FSM, but now I need to reset to code to the default state if I type 'R' into the serial monitor. Any Help? Thanks.
Always show us a good schematic of your proposed circuit. Show us good images of your ‘actual’ wiring. Give links to components.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
would it help if you had a picture of the code I am working on?
Welcome to the forum
Write a function that sets the default state and call it initially from setup() and at any other time that you need to get back to the default state
If you need more detailed help then please post your full sketch, using code tags when you do
A Picture of your code ?
No
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
What is that? Erase the controller to empty without code?
Maybe erase the stuff on the LCD?
Try this version
#include <LiquidCrystal.h>
LiquidCrystal lcd( A5, A4, 5, 6, 7, 8 ); //define pins to use
//                                S t a t e   M a c h i n e
//the states in our machine
enum MachineStates : byte
{STATE_WELCOME, STATE_UP, STATE_UP_FZN, STATE_DOWN, STATE_DOWN_FZN};
MachineStates state = STATE_WELCOME;
int count; // declare count
unsigned long timer; //set up timer
  pinMode(4, INPUT_PULLUP);
  lcd.begin( 16, 2 ); //start LCD lcd.clear(); //clear the display
  count = 0; //set count to 0
  timer = millis(); // timer is counting in milliseconds
} //END of   setup()
  //for testing, slow things down
  //delay(200);
  switch (state)
    case STATE_WELCOME:
      if (digitalRead(4) == LOW)
        Serial.println("up");
        state = STATE_UP;
        //restart the TIMER
        timer = millis();
        lcd.setCursor( 0, 0 );
        lcd.print("WELCOME");
        Serial.println("WELCOME");
    case STATE_UP:
        Serial.println("UP");
        //50ms expired ?
        if ( millis() - timer >= 50 )
          //restart the TIMER
          timer += 50;
          count++;
          lcd.clear();
          lcd.setCursor( 0, 0 ); // sets cursor
          lcd.print( count ); // display count
        state = STATE_UP_FZN;
    case STATE_UP_FZN:
      if (digitalRead(4) == HIGH)
        Serial.println("UP FZN");
        state = STATE_DOWN;
        //restart the TIMER
        timer = millis();
    case STATE_DOWN:
        Serial.println("DOWN");
          //restart the TIMER
          timer += 50;
          if (count > 0)
            count--;
            lcd.clear();
        state = STATE_DOWN_FZN;
    case STATE_DOWN_FZN:
        Serial.println("DOWN FZN");
        state = STATE_UP;
  } //END of  switch/case
  if (Serial.available() > 0)
    char input = Serial.read();
    if (toupper(input) == 'R')
      count = 0;  // Reset the count to 0
      lcd.clear();
      Serial.println("Program reset to WELCOME state.");
} //END of   loop()
