Help concatenating *chars
I am struggling with concatening some *chars
int lineId = 1;
char* RFID= "74986930fh5";
char* CO_OP="A1";
char* VALOR="344";
char* marca="*";
char* str="";
void setup(){
    Serial.println("Lets rock");
void loop(){
  Serial.println("start");
//Make STRING CON lineId + RFID + CO_OP + VALOR + MARCA
  strcpy (str,lineId);
  strcat (str,",");
  strcat (str,RFID);
    strcat (str,",");
  strcat (str,CO_OP);
    strcat (str,",");
  strcat (str,VALOR);
    strcat (str,",");
  strcat (str,MARCA);
  Serial.println(str);
  Serial.println("End");
When I test it, serial outputs trash… any ideas how to fix this.
I need to contact all into a new char*, to MD5 it.
Any help will be much appreciated.
str needs to be declared as a character array with enough room to hold all the characters that you are storing, plus the null on the end. Try:
char str[24];
Also, this statement:
is going to give you problems because lineId is not a string. Either change it to a string or use sprintf to convert it to a string.
Pete
