Help connecting Grid-eye sensor
I accidently ordered the wrong kind of sensor and got Grid-eye onewire
instead of Grid-eye usb. The one I got have two RJ11-connectors and from what I understand uses onewire for communication.
Schematic
I tried to understand the schematic to determine if I could use the TPx connectors at the top to connect and found that TP6 is 1-wire out and TP1 looks like GND, but I do not understand where VCC should go.
So my questions is
1: can I connect it to arduino using onewire and the TPx connections, and how would I connect it in that case.
2: Can I use a FTDI-adapter in some way to be able to connect it to a PC to use the windows-demo-software?
One wire is there to allow long lines.. find datasheet for the sensor chip.. Looks like it can talk I2C
I think you're supposed to use some other kind of boad between tha arduino and the sensor but am hoping there is a way to connect it directly.
From the datasheet:
 MAXREFDES130#, MAXREFDES132#, or equivalent 1-Wire hardware interface.
For Arduino, this interface must use the DS2484 I2C-to-1-Wire master.
 MAXREFDES131#
 mbed or Arduino platform and appropriate USB cable
 PC with USB interface
Arduino
  1. Download the OneWire Library and install it to your libraries folder following the
    directions.
  2. Download the OWGrid-EYE Library (1-Wire Grid-EYE) and install it to your libraries
    folder using the same directions as in step 1.
  3. Connect MAXREFDES130#, MAXREFDES132#, or equivalent 1-Wire hardware
    interface, to your Arduino board.
  4. If using MAXREFDES132#, ensure JP1 is on pins 2-3 and JP2 is removed.
  5. Connect USB cable from the PC to your Arduino board.
  6. Ensure that you have the proper COM port selected in the Arduino IDE “Tools”
    menu.
  7. Download the example program “MAXREFDES131_GUI_Firmware” found under
    the ”1-Wire Grid-EYE” library to your Arduino.
  8. Reset your Arduino.
  9. Navigate to where you installed the MAXREFDES131DemoV1.00 folder.
  10. Double click on the .exe file in the folder and exercise the GUI
I managed to connect the sensor using the SDA and SCL and found some example code. I have only connected SDA,SCL, GND, and VCC. There where some more pins mentioned in the info but I guess they where not needed.
I tried some software and it showed all temeratures correctly in a graphical gui but when I tried the arduino code the serial monitor wass willed with “garbage” even tho I used the the specified baudrate in the serial monitor.
But I clearly see that the serial monitor reacts to my hand and other warm objects. Can I change anything in the code to have a clearer output?
#include <Wire.h>       /*** including the Wire libary needed for the I2C communication ***/
#include <Arduino.h>    /*** including the standard Arduino libary ***/
#define AD_SELECT 19    /*** Define the address select pin ***/
#define INT 18          /*** Define the interrupt pin ***/
#define Hz10  85        /*** Define the delay time [ms] for the 10Hz mode ***/
#define Hz1   985       /*** Define the delay time [ms] for the 1Hz mode ***/
#define ADDR  0x68      /*** Define the I2C address for the Grid-EYE ***/
  /*** join the I2C bus as master ***/
  Wire.begin();
  /*** start the serial Communication with 57600 Bauts ***/
  Serial.begin(57600);
  /*** Set the address pin as an output and set the Grid-EYE ***/
  /*** Slave address to 0x68 (0110 1000) ***/
  pinMode(AD_SELECT, OUTPUT);
  digitalWrite(AD_SELECT,LOW);
  /*** Set interrupt pin as an input pin ***/
  pinMode(INT, INPUT);
  /*** Variable declaration ***/
  byte pixelAddL;
  byte lowerLevel[64];
  byte upperLevel[64];
  byte lowerLevelTherm;
  byte upperLevelTherm;
  short Maindelay = Hz10;
  while(1)
    /*** read out the Thermister tremperature ***/
    Wire.beginTransmission(ADDR);
    Wire.write(0x0E);
    Wire.endTransmission();
    Wire.requestFrom(ADDR, 2);
    lowerLevelTherm = Wire.read();
    upperLevelTherm = Wire.read();
    /*** set pixel address on the first Pixel (low) address ***/
    pixelAddL = 0x80;
    /*** read out the temperature of all 64 Pixel ***/
    for (int pixel = 0; pixel < 64; pixel++)
      Wire.write(pixelAddL);
      lowerLevel[pixel] = Wire.read();
      upperLevel[pixel] = Wire.read();
      pixelAddL = pixelAddL + 2;
    /*** end of read out ***/
    /*** Start Serial communication the temperature readout ***/
    /*** header ***/
    Serial.print('*');
    Serial.print('*');
    Serial.print('*');
    /*** send the thermistor temerature ***/
    Serial.print((char)lowerLevelTherm);
    Serial.print((char)upperLevelTherm);
    /*** send the temperature of the Pixel array ***/
      Serial.print((char)lowerLevel[pixel]);
      Serial.print((char)upperLevel[pixel]);
    /*** check if data was send to the EVB ***/
    if(Serial.available() > 0)
      int command = Serial.read();
      int freq = Serial.read();
      if(freq == 10)  //Set the Grid-EYE to the 10 Hz mode
        Wire.write(0x02);
        Wire.write(0x00);
        Maindelay = Hz10;
      else if(freq == 1) //Set the Grid-EYE to the 1 Hz mode
        Wire.write(0x02);
        Wire.write(0x01);
        Maindelay = Hz1;
      else if(freq == 2) //Set the output Mode of the Grid-EYE to normal
        Wire.write(0x1F);
        Wire.write(0x50);
        Wire.write(0x1F);
        Wire.write(0x45);
        Wire.write(0x1F);
        Wire.write(0x57);
        Wire.write(0x07);
        Wire.write(0x00);
        Wire.write(0x1F);
        Wire.write(0x00);
      else if(freq == 3)  //Set the output Mode of the Grid-EYE to moving average
        Wire.write(0x1F);
        Wire.write(0x50);
        Wire.write(0x1F);
        Wire.write(0x45);
        Wire.write(0x1F);
        Wire.write(0x57);
        Wire.write(0x07);
        Wire.write(0x20);
        Wire.write(0x1F);
        Wire.write(0x00);
    /*** termination of Serial ***/
    Serial.print("\r");
    Serial.print("\n");
    /*** delay for refresh of Grid-EYE data ***/
    delay(Maindelay);
