Help connecting XBee Shield to Mega
I managed to get my xbees communicating using software serial and pins 10 and 11, but I want to use it with the Xbee Shield v3. My XBees are the Pro S1. I am unsure how to do so, and none of the codes I have tried to use work. Does anyone have a working sketch? Or can you help me understand why I can't get them to work on the shield? Thank you.
This is the sketch I am using and is working but without the XBee shield. How do I modify this sketch so that I can use the shield? What pins do I use? Do I still use software serial? Is it that I can't use the monitor simultaneously? Thanks for any help!
Fine. Go right ahead. If you need help, post links to the hardware you are trying to use.
Posting code in 0 point font is silly.
