Help control a 12v 20A electromagnet from ardiuno
I am a bit new to arduino, I need some help with getting the project i need dow.
The basics are this - An arduino will control the output of a 1" wide electromagnet. Right now I am looking for "off/on" control.
The arduino will be powered by the standard voltages. And the magnet by a 12v 20A DC power supply. I should be able to use PWM to trigger a MOSFET which would control the electromagnet.
Pretty simple.
Questions -
1 - I have never used MOSFETS, and can't figure out how to pick them. This thing will have a low 3.5 to 5v trigger from the arduino, but must be able to take the 12v20A that is coming through the MOSFET to the electromagnet.
2 - Best way to achieve this? Like I said MOSFETS are a mystery to me, and all. I just need to get something going so that I can run that ONE magnet. Any suggestion or tutorial?
TIA
hey!
when i did that first i simulated the circuit with QUCS first:
(they have various N-MOSFETs in their database)...
e. g.
1.
u could try 4 BUZ73 in parallel... :slight_smile:
2.
u could try one BUZ12 (min. 30mOhm drain-source resitance)...
it would waste 19.7W (59.3mOhm) with 5V at the gate...
the current would be just 18.2A...
3.
u could try one BUZ12 and a TL061 for voltage translation (0V/5V control voltage to 0V/12V gate voltage; i use the 3.3V for comparison at the positive input of the TL061; CAUTION: the arduino output will have inverted semantics: 5V=off, 0V=on)...
it would waste 10.3W (28.3mOhm) with 12V at the gate...
the current would be just 19.1A...
u should use strong flyback diodes in order to protect the voltage source...
u should be sure that turning on&off the magnet quickly doesnt cause damage to ur voltage source...
u should check if the thermal energy is removed from the circuit/magnet properly...
bye
two IRF1324S might be a good choice, too...
datasheet
together they can provide a current of 19.988A according to QUCS...
There was a previous thread on mosfets. They can be very tricky to drive especially from microcontroller ports.
Try to get a logic level mosfet if you can. If not try using a transistor to drive the gate from by switching the 12 to drive the gate.
If you can get them use a mosfet driver like an IR2110 together with your power mosfets this should work.
