[HELP] Control Arduino car with joystick
Hello guys.
I started with Arduino now, I know only the basics of the basics.
I need to control a car, run by an Arduino, using a bluetooth Joystick.
The Arduino central board has a bluetooth module and 4 motors (one for each wheel) connected to it.
I want to use the bluetooth module to connect with the joystick and control the motors.
It's possible? If so, can you help me with this?
Janvicttor:
Hello guys.
Seems to be possible. What pieces have you tried?
Paul
Paul_KD7HB:
1 - Car
1 - Arduino UNO
1 - Bluetooth Module (HC-05)
1 - Bluetooth Joystick (Mocute)
Images: https://imgur.com/a/CAmdjct
I don't think anyone has done it before.
The closest I can find to what you want is this hack to make the HC-05 into a Bluetooth HID device (turn your Arduino into a Bluetooth keyboard, mouse, or joystick).
Unfortunately, you want the opposite: a way to connect a Bluetooth HID device to your Arduino. There are probably third-party boards like the ESP32 that can receive from a Bluetooth HID device and can be programmed with the Arduino development environment. I am, sadly, not familiar with any specific solution.
In theory you could do it by reverse-engineering the HC-05 firmware but that is a LOT of work.
