I need to use an arduino to convert a bool 0V/open discrete input to a 28V/open input, I have no idea where to start. Any suggestions ?
Do I understand correctly that you need to convert a signal that is 0V/5V to a signal that is 28V/0V? If so, depending on load, a transistor of FET will do.
And an Arduino is not needed for that.
The load is 150kOhm for the 28V/open and 56kOhm for the 0V/open. I'm completely new to Arduino, it's for a project and I was given one.. A transistor would be enough to do this even with this type of load ? Thank you !
A voltage divider from 28V to 5V may be the simplest solution. If required the Arduino can invert the input signal orientation.
Yes, you need to give a proper description of your problem, what it is you want to connect to what, and why. ![]()
What function would an Arduino have in this project? ![]()
I suspect it's the other way around; 0/5V in, 28/0V out.
I take the "open" as a switch state with the other (closed) state connecting to the indicated voltage through the mentioned resistor.
