Help converting from pbasic to Arduino c++
I’m trying to drive a 4 digit led display that works with this BS2 pbasic code but can’t get it to work on the Arduino. Any help you can provide would be helpful.
' HC4LED.BS2
' {$STAMP BS2}
' {$PBASIC 2.5}
Clock PIN 13 ' HC4LED module's Clock pin
Dat PIN 11 ' HC4LED modules's Data pin
value VAR Word ' Required; Holds value to display
zeros VAR Bit ' Required; Determines if leading zeros are displayed
cnt VAR Byte ' Required; Used by display routines
segments VAR Byte (4) ' Required; Used by display routines & customer chars
DO ' Repeat forever
FOR value = 0 TO 1000 ' Count from 0 to 1000
GOSUB DisplayValue ' Display count on HC4LED module
PAUSE 100 ' Wait 0.1 seconds
NEXT ' Next count
PAUSE 1000 ' Wait 1 second
segments(0) = 28 ' 7 ' Setup to display "72°F"
segments(1) = 109' 2
segments(2) = 15 ' °
segments(3) = 71 ' F
GOSUB DisplaySegments ' Display custom characters
PAUSE 2000 ' Wait 2 seconds
LOOP ' Repeat forever
STOP
DisplayValue:
' Call with:
' value = (value to display)
' zeros = (0=No leading zeros; 1=Show leading zeros)
FOR cnt = 0 TO 4
LOOKUP value DIG cnt, [126,24,109,61,27,55,115,28,127,31],segments(3-cnt)
NEXT
IF zeros = 0 THEN
IF segments(0) = 126 THEN
segments(0) = 0
IF segments(1) = 126 THEN
segments(1) = 0
IF segments(2) = 126 THEN
segments(2) = 0
ENDIF
ENDIF
ENDIF
ENDIF
DisplaySegments:
' Call with:
' segments(0) thru segments(3) set to custom character values
' segments(0) is on the left; segments(3) is on the right
SHIFTOUT Dat, Clock, MSBFIRST,[segments(3), segments(2), segments(1), (segments(0) >> 1)\7]
Dat = segments(0) & 1
HIGH Clock
' Clock MUST remain high for at LEAST 1 millisecond for the
' new data to be latched onto the display.
PAUSE 1
RETURN
And this is what I have so far (it does not display correctly but does change the display)
int Clock = 3;  // HC4LED module's Clock pin
int Dat   = 2;  // HC4LED modules's Data pin
int value;       // Required; Holds value to display
int zeros;      // Required; Determines if leading zeros are displayed
int cnt;         // Required; Used by display routines
int segment[4]; // Required; Used by display routines & custom chars
byte digit[10] = {126, 24, 109, 61, 27, 55, 115, 28, 127, 31};
bool debug = true;
  pinMode (Clock, OUTPUT);
  pinMode (Dat, OUTPUT);
  int x;
  for(x = 0; x <= 1000; x++) // Count from 0 to 1000
    DisplayValue(x, 0); // Display count on HC4LED module
    delay (1000); // Wait 1.0 seconds
  } // Next count
  delay(1000); // Wait 1 second
//  segment[0] = 28; // 7 ' Setup to display "72°F"
//  segment[1] = 109;// 2
//  segment[2] = 15; // °
//  segment[3] = 71; // F
//  DisplaySegments(); // Display custom characters
//  delay(2000); // Wait 2 seconds
void DisplayValue(int value, int zeros)
// Call with:
// value = (value to display)
// zeros = (0=No leading zeros; 1=Show leading zeros)
   segment[0] = digit[value / 1000];
   segment[1] = digit[(value - (segment[3] * 1000)) / 100];
   segment[2] = digit[(value - ((segment[3] * 1000)+(segment[2] * 100))) / 10];
   segment[3] = digit[value - ((segment[3] * 1000)+(segment[2] * 100)+(segment[1] * 10))];
  if (zeros = 0)
    if (segment[0] = 126)
      segment[0] = 0;
      if (segment[1] = 126)
        segment[1] = 0;
        if (segment[2] = 126)
          segment[2] = 0;
  DisplaySegments();
void DisplaySegments()
  int seg;
// Call with:
// segment[0] thru segment[3] set to custom character values
// segment[0] is on the left; segment[3] is on the right
  for(seg = 3;seg > 0;seg--)
    if (debug)
  //    Serial.print(seg);
      Serial.print(" - ");
      Serial.print(segment[seg]);
    shiftOut(Dat, Clock, MSBFIRST,segment[seg]);
   if (debug)
      Serial.println((segment[0] >> 1) / 7);
   shiftOut(Dat, Clock, MSBFIRST, (segment[0] >> 1) / 7);
//    Dat = segment[0] & 1;
    digitalWrite (Clock, HIGH);
  // Clock MUST remain high for at LEAST 1 millisecond for the
  // new data to be latched onto the display.
  delay (10);
Got it! Couple of people on the ladyada forum pointed me to some code I rewrote to work.
#define CLOCK  3  //change this to the pin where the clock is going in to
#define DATA   2  // change to the pin where the data wire is plugged in to
#define LED   13  // status led
int led_state;
byte digit[4];
byte number[] = {  126,   //0  numerals (0-9)
                    24,   //1
                   109,   //2
                    61,   //3
                    27,   //4
                    55,   //5
                   115,   //6
                    28,   //7
                   127,   //8
                    31,   //9
                    96,   //A
                    60,   //C
                   103,   //E
                    71,   //F
  pinMode(DATA, OUTPUT);
  pinMode(CLOCK, OUTPUT);
void dispDigit(byte dig, byte flash) {
   for(int i = 0; i < 8; i++) {
      digitalWrite(DATA, (dig & B10000000));     // select high bit
      dig = dig << 1;                                // next bit
      digitalWrite(CLOCK, HIGH);                  // clock high
       if (flash) delay(1);                          // wait to set display on
      digitalWrite(CLOCK, LOW);
void parseValue(int value, int zeros){
     // Call with:
   digit[0] = number[value / 1000];
   digit[1] = number[(value % 1000) / 100];
   digit[2] = number[((value % 1000) % 100) / 10];
   digit[3] = number[((value % 1000) % 100) % 10];
   if (zeros == 0) {
    if (digit[0] == 126) digit[0] = 0;
    if (digit[1] == 126) digit[1] = 0;
    if (digit[2] == 126) digit[2] = 0;
void displayValue(int value, int zeros) {
  int i;
  parseValue(value, zeros);
  for (int i = 3; i > 0; i--) {
    dispDigit((byte)digit[i],0);
  dispDigit((byte)digit[0],1);
  for(int j = 0; j < 1000; j++) {
      displayValue(j, 0);
      led_state = !led_state;
      digitalWrite(LED, led_state);
