im trying to copy the value of "b" the moment the button is pressed and save that as the value of "Sh"
until the encoder is turned
buttonState = digitalRead(buttonPin);
long newPosition = myEnc.read();
if (newPosition != oldPosition) {
oldPosition = newPosition;
float sh = newPosition / 4;
int b = mydata.b;
//sh = constrain(sh, 0, 360);
if (sh > 359) {
myEnc.write(0);
if (sh < 0) {
myEnc.write(1436);
int Sh = sh;
if (buttonState == LOW) {
Sh = b;
delay(50);
Full code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 10, TXPin = 11;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// For stats that happen every 5 seconds
unsigned long last = 0UL;
#include <Wire.h>
#include <EasyTransferI2C.h>
LiquidCrystal_I2C lcd(0x3F, 16, 2);
EasyTransferI2C ET;
#include <Encoder.h>
struct RECEIVE_DATA_STRUCTURE {
//put your variable definitions here for the data you want to receive
//THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
int16_t a;
int16_t b;
RECEIVE_DATA_STRUCTURE mydata;
//define slave i2c address
#define I2C_SLAVE_ADDRESS 9
const int buttonPin = 4; // the number of the pushbutton pin
// variables will change:
int buttonState = 0;
int lastbuttonState = 0;
int newSh = 0;
int oldSh = 0;
Encoder myEnc(2, 3);
ss.begin(GPSBaud);
pinMode(buttonPin, INPUT);
Wire.begin(I2C_SLAVE_ADDRESS);
//start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
ET.begin(details(mydata), &Wire);
//define handler function on receiving data
Wire.onReceive(receive);
lcd.init();
lcd.backlight();
lcd.setCursor (3, 0);
lcd.print("Autopilot!");
delay(1500);
lcd.clear();
long oldPosition = -999;
if (ET.receiveData()) {
Serial.print("hi");
// Dispatch incoming characters
while (ss.available() > 0)
gps.encode(ss.read());
int head = gps.course.deg();
int valH = head;
// int sh;
int sa;
//sh = 270;
sa = 1500;
int b = mydata.b;
if (sh > 359) {
myEnc.write(0);
if (sh < 0) {
myEnc.write(1436);
int Sh = sh;
Sh = b;
delay(50);
lcd.setCursor(0, 0);
lcd.print("CH:");
lcd.setCursor(3, 0);
lcd.print(b);
lcd.print(" ");
lcd.setCursor(9, 0);
lcd.print("A:");
lcd.setCursor(11, 0);
lcd.print(mydata.a);
lcd.print(" ");
lcd.setCursor(0, 1);
lcd.print(">H:");
lcd.setCursor(3, 1);
lcd.print(Sh);
lcd.print(" ");
lcd.setCursor(6, 1);
lcd.print("");
lcd.setCursor(8, 1);
lcd.print(">A:");
lcd.setCursor(11, 1);
lcd.print("1500");
lcd.print(" ");
Serial.println(sh, 0);
void receive(int numBytes) {}
