HElP, Counter to 9 with a shift register without delay not working
hello everybody, thank you in advance for your reply and help, I make counter from 0 to 9 without delay but i can not make it , can me some one remodel code to see how it would work out with the function of Millis. https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
const int latchPin = 2; const int dataPin = 3; const int clockPin = 4;
int ledState1 = LOW; int ledState2 = LOW; int ledState3 = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
pinMode(latchPin, OUTPUT); pinMode(dataPin, OUTPUT); pinMode(clockPin, OUTPUT); }
if (currentMillis - previousMillis >= interval) {
if (ledState1 == LOW) { ledState1 = HIGH; } else { ledState1 = LOW; }
digitalWrite(latchPin, ledState1);
if (ledState2 == LOW) { ledState2 = HIGH; } else { ledState2 = LOW; }
digitalWrite(dataPin, ledState2);
if (ledState3 == LOW) { ledState3 = HIGH; } else { ledState3 = LOW; }
digitalWrite(clockPin, ledState3);
//0 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 64); digitalWrite(latchPin, HIGH); //1 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 121); digitalWrite(latchPin, HIGH);
//2 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 36); digitalWrite(latchPin, HIGH);
//3 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 48); digitalWrite(latchPin, HIGH);
//4 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 25); digitalWrite(latchPin, HIGH);
//5 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 18); digitalWrite(latchPin, HIGH);
//6 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 2); digitalWrite(latchPin, HIGH);
//7 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 120); digitalWrite(latchPin, HIGH);
//8 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 0); digitalWrite(latchPin, HIGH);
//9 digitalWrite(latchPin, LOW); shiftOut(dataPin, clockPin, MSBFIRST, 24); digitalWrite(latchPin, HIGH);
      ledState3 = HIGH;
      ledState3 = LOW;
Why are you toggling the clock (and data) pin every second? Did the example using delay() do that? I doubt it.
I don't understud you
