HElP, Counter to 9 with a shift register without delay not working
hello everybody, thank you in advance for your reply and help,
I make counter from 0 to 9 without delay but i can not make it , can me some one remodel code to see how it would work out with the function of Millis.
const int latchPin = 2;
const int dataPin = 3;
const int clockPin = 4;
int ledState1 = LOW;
int ledState2 = LOW;
int ledState3 = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
if (currentMillis - previousMillis >= interval) {
if (ledState1 == LOW) {
ledState1 = HIGH;
ledState1 = LOW;
digitalWrite(latchPin, ledState1);
if (ledState2 == LOW) {
ledState2 = HIGH;
ledState2 = LOW;
digitalWrite(dataPin, ledState2);
if (ledState3 == LOW) {
ledState3 = HIGH;
ledState3 = LOW;
digitalWrite(clockPin, ledState3);
//0
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, 64);
digitalWrite(latchPin, HIGH);
//1
shiftOut(dataPin, clockPin, MSBFIRST, 121);
//2
shiftOut(dataPin, clockPin, MSBFIRST, 36);
//3
shiftOut(dataPin, clockPin, MSBFIRST, 48);
//4
shiftOut(dataPin, clockPin, MSBFIRST, 25);
//5
shiftOut(dataPin, clockPin, MSBFIRST, 18);
//6
shiftOut(dataPin, clockPin, MSBFIRST, 2);
//7
shiftOut(dataPin, clockPin, MSBFIRST, 120);
//8
shiftOut(dataPin, clockPin, MSBFIRST, 0);
//9
shiftOut(dataPin, clockPin, MSBFIRST, 24);
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What is your code doing?
Please don't post many times for the same issue. You are wasting everyone's time. That is very poor practice
Why do you use ledState to toggle data, latch and clockpin? I am pretty sure it is a bad idea to manipulate data and clockpin. Is it left overs from copied code?
It looks like you have a 7 segment display, but you send every digit in sequence instead of 1 digit every second. You need a counter to keep track of which number you have sent.
A good way to do that is to put your segment encoded numbers in an array. When counter is 5 you send value 5 from your array.
