Woops, sorry about that. Heres the code that I currently have set up for Knock Sensor:
/* Knock Sensor
* Program using a Piezo element as if it was a knock sensor.
* We have to basically listen to an analog pin and detect
* if the signal goes over a certain threshold. It writes
* "knock" to the serial port if the Threshold is crossed,
* and toggles the LED on pin 13.
* (cleft) 2005 D. Cuartielles for K3
int ledPin = 13;
int knockSensor = 0;
byte val = 0;
int statePin = LOW;
int THRESHOLD = 100;
pinMode(ledPin, OUTPUT);
beginSerial(9600);
val = analogRead(knockSensor);
if (val >= THRESHOLD) {
statePin = !statePin;
digitalWrite(ledPin, statePin);
printString("Knock!");
printByte(10);
printByte(13);
delay(100); // we have to make a delay to avoid overloading the serial port
I want to set it so that each Knock turns on the light but turns it off as well right after.
However, I don't think the Piezo sensor is the right tool to use for my project, since it only picks up direct almost physical "taps". Perhaps a microphone.
Thanks for the insightful Grumpy!
