I'm trying to create a finite state machine with three different states that can be toggled between by entering 0 or 1 in the serial monitor. I'm using switch and case for it.
The issue I am having is when I want to switch to case C from B, it will revert back to case B without any input. Why is this?
The usual reason for using a state machine is to avoid blocking. This destroys that benefit completely by blocking any other code, until some input comes along. Use
if (Serial.available() )
I'm not sure if the braces {} in each of your case statements are screwing up your switch statement, but they don't belong there. Go look up the switch/case statement documentation.
I think you don't understand the purpose of loop(). It is supposed to run thousands of times a second. Not halt to do this, halt to do that.
the stimulus in a particular state doesn't require a state change.
there are two types of states machines: one when the action depends on the state and the second where the action depends on the transition (the state and the stimulus). a stimulus can be back to the same state
case 'C':{
if (UserInput == 1)
NextState = 'A';
else if(UserInput == 0)// in this case you're always switch back to this state
NextState = 'B';//set another state then 'B' as Nextstate
}break;
The Serial.parseInt() will return 0 if no integer is found in the timeout interval. Make sure you have the line ending menu at the bottom of Serial Monitor set to "No line ending".
aarg:
You need to use braces in cases if you introduce local variables.
Otherwise, they do no harm.
