Help cross check code
#include <IRremote.h>
const int RECV_PIN=5;
#define code1 0xFF18E7 //button 2
#define code2 0xFF4AB5//button 8
#define code3 0xFF10EF //button 4
#define code4 0xFF5AA5 //button 6
#define code5 0xFF38C7 //button 5
IRrecv irrecv(RECV_PIN);
decode_results results;
int in1 = 7;
int in2 = 8;
int ENA = 9;
int in3 = 10;
int in4 = 11;
int ENB = 12;
irrecv.enableIRIn();
pinMode (in1,OUTPUT);
pinMode (in2,OUTPUT);
pinMode (ENA,OUTPUT);
pinMode (in3,OUTPUT);
pinMode (in4,OUTPUT);
pinMode (ENB,OUTPUT);
irrecv.blink13(true);
if (irrecv.decode (&results))
switch (results.value){
case code1:
digitalWrite(in1,HIGH);
digitalWrite(in2,LOW);
digitalWrite(in3,HIGH);
digitalWrite(in4,LOW);
analogWrite(ENA,255);
case code2:
digitalWrite(in1,LOW);
digitalWrite(in2,HIGH);
digitalWrite(in3,LOW);
digitalWrite(in4,HIGH);
case code3:
case code4:
case code5:
analogWrite(ENA,0);
analogWrite(ENA,0);
irrecv.resume();
Please edit you code to use code-tags. See "How to use the forum".
Next, what is the problem?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model Arduino are you using?
Thanks.. Tom.. :slight_smile:
Yes, I'm very cross.
HTH
Yep, it looks like code.
Romonaga:
Yep, it looks like improperly posted code.
Fixed that for you :wink:
Before posting a question here please run your program.
If it works properly there will be no need to ask a question.
If it does not work properly then by telling us exactly what it does do and what you want it to do that is different you will be providing a lot of useful information with which to help you.
The Arduino system is great for learning-by-doing
...R
