Help! D:
hi im trying to connect current sensor ACS712 with the arduino. however it seems like the output of the ACS712 is always fixed no matter how much voltage i apply it. can someone show me how i should connect it????? thanks :)
Show us how you have connected it, or, do a search in the box at top of page.
Weedpharma
this is how i connect my circuit
Please supply a picture that allows us to see the connection details rather than a low resolution blur.
Weedpharma
here you go. this is how i connected my circuit
The amount of current passing through the sensor will be so small it will be hard to detect a change as you vary the voltage.
With a 1k resistor and a LED you'll be getting about 10mA of current. The sensor outputs 185mV/A so with 10mA the sensor should be outputting 1.85mV. Each unit from the Arduino's ADC represents about 5mV.
I think you're not passing nearly enough current through the sensor to be detected.
BTW, As instructed by the thread "How to use this forum", please use a meaningful title to your post. If every person asking for help titled their thread "Help", the lists of posts would be pretty meaningless.
so does it help by increasing/decreasing the gain or the volt ref?
These devices are meant to measure Amps rather than mA. The resolution is too low for very small currents.
Test the circuit using a larger current draw. Say something drawing an Amp or two.
Weedpharma
randytan: so does it help by increasing/decreasing the gain or the volt ref?
I doubt it.
Do what Weedpharma suggests. Also edit your original post to give this thread a proper title. Something like the title of my reply should help others know what this thread is about.
