Help decoding clamp meter
I'm trying to get a clamp meter signal into Home Assistant, but I've hit as far as A.I. can get me.
Situation is... Geo Minim+ power meter with a clamp meter which is broadcasting roughly every few seconds. I have a CY121-868.325ASK module hooked up to an ESP32 C3 and it is returning RAW values which AI has confirmed contains packets from the meter. (at least, that's what it says!)
AI seems unable to decode what's coming back despite having given it two separate captures when I know what reading is showing on the in home display. There seems to be a chunk of noise coming through.
Basically, I've got no clue what I'm looking at, a piece of AI obtained "decoding" python script noted it found 179 pulses, found 1 packet and it was all zeros.
I'm at a loss now and don't know where to go with this, or how to get anything useful out of the raw data, because I haven't got a clue what I'm looking at.
eg...
[12:28:09.156][I][remote.raw:041]: Received Raw: -5312, 833, -5052, 260, -10416, 833, -990, 208, -13020, 468, -1198, 1042, -4531, 937, -5624, 469
[12:28:09.174][I][remote.raw:041]: Received Raw: -469, 625, -5885, 208
[12:28:09.210][I][remote.raw:041]: Received Raw: -6093, 781, -729, 209, -937, 260, -4531, 209, -2291, 364, -3750, 208, -2656, 417, -12968, 2395, -1094
[12:28:09.231][I][remote.raw:041]: Received Raw: -3385, 209
...this means nothing to me.
Hi, @msknight
Welcome to the forum.
Can please post link to data/spec of the clamp meter?
Can you please post your code?
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
Hi Tom,
I'm actually flying blind. This is what I've written so far about my journey...
A.I. returns generic information only, and I contacted Geo and they didn't provide me with anything. The clamp meter is powered by three AA batteries and the Geo Minim+ user manual can be found here, but offers no technical information...
AI provided me with simple ESP32 code...
remote_receiver:
  pin:
    number: GPIO1
    inverted: false   # try true if nothing shows
  dump: raw
  idle: 2ms
  filter: 200us
  tolerance: 40%
  buffer_size: 30kb
...which has been capturing the raw data.
Michelle.
How are you getting the data from the power monitor?
It is being (hopefully) received by the CY121-868.325ASK module which is connected to the ESP32 C3 and I'm looking at the logs from the ESP32 C3 to see what it says has come back.
This is what I'm seeing.
Likely not. That device is listed as FSK on rtl_433 library.
According to the manual this device is only measuring current. Since it doesn't measure voltage and consider power factor, it's just a toy.
Get Shelly EM, works with HA out of the box.
Shelly requires mains power. As do many others. That isn't available to me here, hence I'm trying to use this.
What are you measuring then?
The clamp meter is clamped to the live from the electricity meter, but there is no mains socket near to plug the transmitter into, so the transmitter is powered by three AA batteries.
You don't need to connect it next to meter. You can connect Shelly in your panel where circuit brakers are. Your electrician knows how to do it.
That toy can easily have an error of 30%, maybe more.
Toy it may be, but it's all I've got. There's no space in my circuit breakers to put anything else.
When your electrician unscrews the panel, you will see that there's space for Shelly.
I don't see any point to invest in hardware to capture that FSK signal. And you don't have too much options either, maybe SX127x with Esphome or RTL-SDR dongle directly to HA.
Keep going fw with AI?
This is my first foray into signal analysis... which is what I originally came here for. As a result, I now know that I've been barking up the wrong tree trying to analyse an ASK signal which is actually garbage. I knew nothing about the existence of RTL_433 until I posted here.
I also don't know how to access the library beyond the listing, so I don't know how to extract the protocol I need. Indeed, if I read correctly, only part of the protocol has been decoded.
I've also got no clue how to wire the CC1101 Wireless Module to the C3 or code for it. (which I bought as a backup when I was looking at the CY121-868.325ASK module, but decided not to use because it was more complex and would require more wires and programming) So I've got no choice other than to lean in to AI... which, once it's corrected on various things can move forward. It seems aware of the pin outs and the code needed as it is pulling from web sites where others have done this before.
My society seems to have entered a point in time where it is getting difficult to learn certain things from scratch. There's a lot of information around, but not organised into a way I can learn from. I want to learn electronics and years ago there used to be Maplin Electronics and learning was easy because there were not only books, but people to help. Now, the electronics components shops are shutting down, courses are sporadic and the books cover old technology and haven't kept pace. The only way I could learn was signing up to a three year course at a local university in my area.
In the mean time, I have things that I need to achieve. To be fair, most of them I've managed to do, and yes, that has been with the help of AI. And I'm documenting my efforts, including my mis-steps, for others.
I've been on some forums for help and it has been hit and miss. Some people have been very kind and patient. Others have been quite curt and impolite. I'm just trying to move forward any way I can.
CC1101 should be good for that, afaik it doesn't have native esphome component though.
It's the first result if you google search for: "minim+" 433mhz
If I was you, I would study basics of power monitoring. To understand why you need to measure current, voltage and phase shift of them. Your nominal voltage can vary 10%. In modern house full of electronics, the power factor can be anything between 1 and 0.5 depending on what loads you have on at that moment.
So a gadget that only measures current can't really give even good estimation or real power that your electric meter counts. Neither is possible to "calibrate" it anyhow.
At least mention this on your blog, so no reader buys that device with illusions.
Ps. You might be interested on this:
Does that go for all the other clamp meters that people are using for Home Assistant?
If it's going to be something deep like this, I don't go to a search engine and I go straight to AI because it can interpret slightly deeper queries, especially when I don't know what I'm looking for to begin with.
Thanks for that link. I'll give it a read. And I'll add your quote to the blog as well. At the moment people can't find it without the direct URL. I'll add it to the menu when I've finished making a hash of the project :slight_smile:
No, only your gadget. And proposed shelly em uses clamp as well.
Please don't quote me, just make your research.
TMHO you over-valuate AI, good luck with that.
Just checking, I'm using 868. With all the talk about 433, I am using the right frequency here, yes? Or is the minim+ on 433 and I'm on the wrong frequency as well as the wrong modulation!
I don't know your device, but library gives:
Frequency 868.29 MHz, bit period 25 microseconds (40kbps), modulation FSK_PCM
Are you sure your CC is for 868?
