Help decoding Serial Data from Mitutoyo Protractor [Solved]
Hello everybody,
I'm having a lot of issues trying to send to the serial monitor the output from the Mitutoyo Protractor PRO-3600.
According to the manual, the PRO-3600 has a 5V serial output, 9600 bps 8N1 with ASCII format. However, I'm not getting the right values. Some values are higher than 127.
The manual is here
The output format: XXX.XX , 9 bytes as I understand.
I wrote a simple sketch in a MEGA2560:
#define REQ 5
  Serial3.begin(9600);
  pinMode(REQ, OUTPUT);
  digitalWrite(REQ, LOW);
  delay(100);
  Serial.println("Ready!");
  digitalWrite(REQ, HIGH);
int count = 0;
  while(Serial3.available() > 0)
    byte c = Serial3.read();
      Serial.print(c, DEC);
      Serial.print(" ");
    if (count++ == 8)
      count = 0;
The serial monitor shows:
Output:
105 235 159 163 151 151 229 235 0
105 251 171 163 159 145 229 235 0
106 203 153 163 151 153 229 235 0
106 139 159 163 153 147 229 235 0
106 219 153 163 149 145 229 235 0
105 219 159 163 153 149 229 235 0
106 251 155 163 151 155 229 235 0
Byte number:
 0   1   2   3   4   5   6   7  8
Byte 0, sometimes change while moving the PRO-3600 between 105 and 106, I'm guessing that byte represents the sign.
Bytes 4, 6, 7 and 8, never change. So, according to the format, I'm guessing that they represent the decimal point, carriage return and line feed. The '0' I don't know.
The maximum value showed in the PRO-3600 display is 90.0° and the minimum is 0.00°
Do you guys have any idea of what I'm doing wrong?
Thanks in advance!
Efel
The output may be 5V but it's RS232. You need a RS232/TTL converter or some level changing circuitry. When negative level signals are received the response of the USART is undefined. RS232 operates of +/- signals as detailed on p.8 in the manual. TTL operates on 0/5V.
Byte 3 (not 4) is likely the interpretation of a decimal point while 6 and 7 appear to be . The zero appears because you are reading 9 bytes. The first byte is likely lost as the signal expected to begin reception (typically a high-low transition) is not being received correctly. In all, the data is garbage because of the RS232/TTL level issue. Get the convertor, they're about a buck.
That means CHARACTERS.
So, why are you not reading CHARACTERS?
From the manual: "Pro 3600 Serial Port The Pro 3600 has an ASCII-format RS-232 compatible serial port for remote angle readout." This means that the logic levels are inverted, and they go negative. Try using the SoftwareSerial library which has a way to invert the logic:
SoftwareSerial Pro3600Port(RXPin, TXPin, true);  // The 'true' means to invert the signal
In theory, applying -5V to an input pin could damage the Arduino. A diode in the data line with the anode (+) pointing to the Pro 3600 and the cathode (-) pointing to the Arduino should block the negative voltage. This might require a pull-down resistor (10k?) on the input pin.
You are getting data because the Serial input ignores framing errors. ANY high-going edge will be taken as the beginning of a Start Bit. The Arduino will read the next 8 pulse times and present it as a byte. Since the logic is inverted, it's seeing any Mark to Space transitions as a start bit and returning whatever is after that. Your data is inverted and shifted.
DKWatson and johnwasser, thanks a lot for your replies
DKWatson:
DKWatson, you are absolutely right!
Thanks a lot for let me know my mistake. Here in my location is not fast/easy to get the converter, I ordered it online, and in couple days it will arrive, then I will continue the final implementation.
In the mean time, I tryed the suggestion from johnwasser, just a little bit different.
johnwasser:
From the manual: "Pro 3600 Serial Port The Pro 3600 has an ASCII-format RS-232 compatible serial port for remote angle readout." This means that the logic levels are inverted, and they go negative. Try using the SoftwareSerial library which has a way to invert the logic...
I don't why the SoftwareSerial didn't work. However, I used a NPN transistor to invert the logic and the Serial3. Now, I have the correct output.
:slight_smile:
-   1 8 . 6 1
-   1 9 . 5 6
-     5 . 6 7
-     6 . 1 5
-     2 . 7 0
+     0 . 1 5
-     0 . 5 6
Thanks again guys!
Kind Regards!
Which pins did you try it on ?
UKHeliBob:
Hello UKHeliBob,
I tried in several pins, 10 and 11, according to this link -> https://www.arduino.cc/en/Reference/SoftwareSerial
So maybe the board is damage.
Regards!
