Help Displaying Temp On Two 7-Pin LEDs
You really really need to find out about arrays and look at examples of much simpler 7-segment LED drivers out there!
You probably still have "if (temp = 69)" in your code by the sound of it.
At the very least you should (re)factor the code to avoid all the dumb repetition, something like this as a framework would be a start:
void loop ()
  read () ;
  int high_digit = temp / 10 ;
  int low_digit = temp % 10 ;
  switch (high_digit)
  case 0:  .... ; break ;
  case 1:  .... ; break ;
  case 2:  .... ; break ;
  case 9:  .... ; break ;
  switch (low_digit)
  delay (10) ;   // allow time to pass to reduce LED flicker
But there's more to do to clean it up - and learn a lot in the process I think.
