help ditching delay
hello all, i have a code which works just fine with delay() but as i want to add some other functions the delay becomes a problem. I have looked tru some sketches using millis() but i have not found a sketch to learn how i can go around the delay in my sketch.
does anyone have some pointers to look at, or is my sketch not possible with the use of millis
#include "FastLED.h"
// Number of leds in 1 strip
#define NUM_LEDS 83
DEFINE_GRADIENT_PALETTE( Sunrise_gp )
   51,  0,  0, 51,  // Midnight blue
  101,   0,   0, 150,  // Deepsky blue
  151,   10,   10, 212,  // Medium blue
  201, 25, 25, 205,  // Lightsky blue
  241, 50, 50, 205,  // Lightsky blue
  255,  100,  100, 200}; // Daylight
CRGBPalette16 myPal = Sunrise_gp;
    // Define the array of leds
    CRGB ledstrip_1[NUM_LEDS];
    CRGB ledstrip_2[NUM_LEDS];
    CRGB ledstrip_3[NUM_LEDS];
    CRGB ledstrip_4[NUM_LEDS];
    FastLED.addLeds<WS2812B, 4, GRB>(ledstrip_1, NUM_LEDS);
    FastLED.addLeds<WS2812B, 5, GRB>(ledstrip_2, NUM_LEDS);
    FastLED.addLeds<WS2812B, 6, GRB>(ledstrip_3, NUM_LEDS);
    FastLED.addLeds<WS2812B, 7, GRB>(ledstrip_4, NUM_LEDS);
  sunrise();
    FastLED.show();
void sunrise() {
  // total sunrise length, in minutes
  static const uint8_t sunriseLength = 3;
  // how often (in seconds) should the heat color increase?
  // for the default of 60 minutes, this should be about every 14 seconds
  // 14 seconds x 256 gradient steps = 3,584 seconds = ~60 minutes
  static const float interval = ((float)(sunriseLength * 60) / 256)*1000;
  // current gradient palette color index
  static uint8_t heatIndex = 0; // start out at 0
    // current used color palette
    CRGB color = ColorFromPalette(myPal, heatIndex);
    // fill the entire strip with the current color palette starting on 1 side
  for ( byte i = 0; i < NUM_LEDS; i++ ) {
    ledstrip_1[i] = CRGB(color);
    ledstrip_2[i] = CRGB(color);
    ledstrip_3[i] = CRGB(color);
    ledstrip_4[i] = CRGB(color);
    FastLED.delay(1000);
  // slowly increase the heat
  EVERY_N_MILLISECONDS(interval ) {
    // stop incrementing at 255, we don't want to overflow back to 0
    if(heatIndex < 255) {
      heatIndex++;
Have you read Using millis() for timing. A beginners guide, Several things at the same time and looked at the BlinkWithoutDelay example in the IDE ?
i did, and i have tried to implement it into my sketch but i only could light up all the leds at once or only the first led of each strip. i dont know how to update the leds to start lighting up from 1 side but this is the last sketch i was working on before i stopped.
#define NUM_LEDS 83
unsigned long previousMillis = 0;        // will store last time LED was updated
// constants won't change :
const long interval = 500;           // interval at which to blink (milliseconds)
  101,   0,   50, 150,  // Deepsky blue
  151,   10,   75, 212,  // Medium blue
  201, 25, 150, 205,  // Lightsky blue
  255,  100,  180, 200}; // Daylight
  sunrise();
    FastLED.show();
void sunrise() {
    if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
      heatIndex++;
never your with FastLED library so not sure what " FastLED.show();" is supposed to do, I thins something like thing may work… possibly with " FastLED.show();" inside "sunrise routine.
#define NUM_LEDS 83
uint8_t i = 0;
  255,  100,  180, 200
}; // Daylight
  sunrise();
  FastLED.show();
void sunrise() {
  static const float interval = ((float)(sunriseLength * 60) / 256) * 1000;
      if (heatIndex < 255) {
        heatIndex++;
    i = (i + 1) % NUM_LEDS;
Hope that helps
You have a couple of things going on… If you use millis() for timing, you don’t need to use the EVERY_N_MILLISECONDS() function from the FastLED library. I would also suggest moving all the timing stuff into the main body of loop() rather than buring it inside sunrise(). Here’s a cleaned up version:
#define NUM_LEDS 83
//const unsigned long interval = 500;           // interval at which to blink (milliseconds)
  255,  100,  180, 200
}; // Daylight
const unsigned long interval = sunriseLength * 60000UL / 256; // milliseconds
    // time to update leds
      heatIndex++;
    sunrise();
    FastLED.show();
void sunrise() {
    //ledstrip_1[i] = CRGB(color);
    //ledstrip_2[i] = CRGB(color);
    //ledstrip_3[i] = CRGB(color);
    //ledstrip_4[i] = CRGB(color);
    ledstrip_1[i] = color;
    ledstrip_2[i] = color;
    ledstrip_3[i] = color;
    ledstrip_4[i] = color;
Also note that you where filling in the ledstrip arrays incorrectly. You don’t want to transform the variable ‘color’ into a CRGB type since it already is.
@ sherzaad
the FastLED.show command is used to clear the leds and start the new lightprogram
@blh64
Thnx for the clean up, i am still a newbie so i thought my code would be a little messy:P
mostly its due to the fact that i have a existing code that works and tru trial and error i try to make the code work better and also learn in the proces.
I have tried your cleaned up version and it works, now i can do a side by side comparison to improve my cleanup skills, but it also lights up all the led at once.
i am trying to find a way to use millis to light up the leds starting on 1 side lighting 1 led after the other.
it did work fine with delay but that gives me problems in my bigger project which include a lcd which freezes when the sunrise starts
inside your sunrise() function, you iterate over all the LEDs and set them to a color.
Why would you expect that NOT to turn on all your LEDs? If you want to slowly increase the number of LEDs that are lit up, you need to figure out how many you want and then just assign to those and leave the rest off (black). Rather than using the heatIndex variable, it sounds like you need another variable that gets incremented from 1…NUM_LEDS.
Give it a shot, if it doesn’t work, post the code and ask for help.
I would expected that they would light up one after the other cause it did work fine with delay function.
The heatindex function tells the arduino which colors to show not which led to light up.
But i will try to give it a go, if it does not work i will post the sketch again
changed the for loop to a static int and now it works like a charm
