Help! does not work gps neo6mv2
Good morning, I need to use a neo6mv2 gps module, but I have not managed to make it work, I tried the library that comes for arduino "TinyGps" and on the serial monitor at 115200 baud, it shows me only Chars, sentences and checksum. I do not know if it's because I'm using the gps in basement 2 of the university and it does not reach to connect to any satellite or is that my gps has been damaged in some way.
I am using an arduino one, the gps powered at 3.3 v, does not turn on the blue light of the gps,the gps does not give me coordinates, I appreciate your help. :slight_smile:
cast144:
So if you suspected your GPS might not be able to recieve the satellites 2 floors underground, did it not occur to you to try it outside ?
A budding scientist, to be sure.
