Help. dual stepper control with potenciometer
Please help. I Am stck :o
/* FILE: HCMotor_Stepper_Example
DATE: 09/07/15
VERSION: 0.1
AUTHOR: Andrew Davies
This example uses the library to control a stepper motor via a standard stepper driver
module (with step/clock & direction inputs) using a potentiometer connected to
analogue pin A0. For suitable driver modules see items HCMODU0022 & HCMODU0068.
Do not connect the motor directly to your Arduino’s digital pins as you may damage your
Arduino.
Note about driving more than one motor:
By default this library can drive up to 4 motors. However this can be increased by
editing the following line in the libraries HCMotor.h file:
#define MAXMOTORS 4 ← change to match the number of motors you require.
If you are using less than 4 motors and your sketch is processor intensive you may
also want to reduce this value to match the number of motors you have attached as this
will free up processing cycles for your main loop.
You may copy, alter and reuse this code in any way you like, but please leave
reference to HobbyComponents.com in your comments if you redistribute this code.
This software may not be used directly for the purpose of selling products that
directly compete with Hobby Components Ltd’s own range of products.
THIS SOFTWARE IS PROVIDED “AS IS”. HOBBY COMPONENTS MAKES NO WARRANTIES, WHETHER
EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ACCURACY OR LACK OF NEGLIGENCE.
HOBBY COMPONENTS SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR ANY DAMAGES,
INCLUDING, BUT NOT LIMITED TO, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES FOR ANY
REASON WHATSOEVER.
/* Include the library */
#include “HCMotor.h”
/* Pins used to drive the motors */
#define DIR_PIN 8 //Connect to drive modules ‘direction’ input.
#define CLK_PIN 9 //Connect to drive modules ‘step’ or ‘CLK’ input.
#define DIR_PIN1 10 //Connect to drive modules ‘direction’ input.
#define CLK_PIN1 11 //Connect to drive modules ‘step’ or ‘CLK’ input.
/* Set the analogue pin the potentiometer will be connected to. */
#define POT_PIN A0
#define POT_PIN1 A1
/* Set a dead area at the centre of the pot where it crosses from forward to reverse */
#define DEADZONE 20
/* The analogue pin will return values between 0 and 1024 so divide this up between
forward and reverse */
#define POT_REV_MIN 0
#define POT_REV_MAX (512 - DEADZONE)
#define POT_FWD_MIN (512 + DEADZONE)
#define POT_FWD_MAX 1024
#define POT_REV_MIN1 0
#define POT_REV_MAX1 (512 - DEADZONE)
#define POT_FWD_MIN1 (512 + DEADZONE)
#define POT_FWD_MAX1 1024
/* Create an instance of the library */
HCMotor HCMotor;
//Serial.begin(9600);
/* Initialise the library */
HCMotor.Init();
/* Attach motor 0 to digital pins 8 & 9. The first parameter specifies the
motor number, the second is the motor type, and the third and forth are the
digital pins that will control the motor */
HCMotor.attach(0, STEPPER, CLK_PIN, DIR_PIN);
/* Attach motor 0 to digital pins 10 & 11. The first parameter specifies the
HCMotor.attach(1, STEPPER, CLK_PIN1, DIR_PIN1);
/* Set the number of steps to continuous so the the motor is always turning whilst
not int he dead zone*/
HCMotor.Steps(0, CONTINUOUS);
HCMotor.Steps(1, CONTINUOUS);
static int Speed, Pot;
/* Read the analogue pin to determine the position of the pot. */
Pot = analogRead(POT_PIN);
/* Is the pot in the reverse position ? */
if (Pot >= POT_REV_MIN && Pot <= POT_REV_MAX)
HCMotor.Direction(0, REVERSE);
Speed = map(Pot, POT_REV_MIN, POT_REV_MAX, 10, 1024);
/* Is the pot in the forward position ? */
} else if (Pot >= POT_FWD_MIN && Pot <= POT_FWD_MAX)
HCMotor.Direction(0, FORWARD);
Speed = map(Pot, POT_FWD_MIN, POT_FWD_MAX, 1024, 10);
/* Is the pot in the dead zone ? */
} else
Speed = 0;
/* Set the duty cycle of the clock signal in 100uS increments */
HCMotor.DutyCycle(0, Speed);
int Speed, Pot;
Pot = analogRead(POT_PIN1);
if (Pot >= POT_REV_MIN1 && Pot <= POT_REV_MAX1)
HCMotor.Direction(1, REVERSE);
Speed = map(Pot, POT_REV_MIN1, POT_REV_MAX1, 10, 1024);
} else if (Pot >= POT_FWD_MIN1 && Pot <= POT_FWD_MAX1)
HCMotor.Direction(1, FORWARD);
Speed = map(Pot, POT_FWD_MIN1, POT_FWD_MAX1, 1024, 10);
} else
Speed = 0;
HCMotor.DutyCycle(1, Speed);
here is the error
Arduino:1.6.7 (Windows 7), Kort"Arduino/Genuino Uno"
HCMotor_Stepper_Example:135: error: ‘Pot’ does not name a type
HCMotor_Stepper_Example:138: error: expected unqualified-id before ‘if’
HCMotor_Stepper_Example:144: error: expected unqualified-id before ‘else’
HCMotor_Stepper_Example:151: error: expected unqualified-id before ‘else’
} else
HCMotor_Stepper_Example:158: error: ‘HCMotor’ does not name a type
HCMotor_Stepper_Example:160: error: expected declaration before ‘}’ token
exit status 1
Denne rapporten vil inkludere mer informasjon med
“Vis detaljert informasjon under kompilering”
skrudd på i Fil > Innstillnger
Match your {} braces.
(and use code tags. But you knew that)
Match your {} braces. :o what does that mean is that the answer to my problem, :confused:
Yes, it is the answer to your problem.
Check where loop()'s opening { is. Now find the matching } to this.
Is there any code after this? is that code in a function?
