HELP ! Egizmo Power Analyzer
Help po ! Baka meron po sainyo nakaka alam ng power analyzer ng egizmo, Hindi ko po kasi alam ang gagawin dito, yung project po namin ito ang main feature. I ask po sa iba ng codes and meron na po ang hindi lang po namin alam ay yung kung pano mag-pa-appear yung data sa serial monitor. Salamat po sa tutulong. Eto po yung codes na gamit ..
#include <SoftwareSerial.h>
char rxbyte;
int  i;
char * range;
char * watts;
char * va;
char * var;
char * pf;
char * volts;
char * amps;
char padata[53];
bool StartDataReceived = false;
bool DataAvailable = false;
SoftwareSerial mySerial(2, 3);
	mySerial.begin(9600);
	if (mySerial.available() > 0)
		rxbyte = mySerial.read();
		if ( rxbyte == 'I')
			StartDataReceived = true;
			padata[0] = rxbyte;
	if (( StartDataReceived == true) && ( mySerial.available() > 0))
		for ( i = 1; i < 53; i++ )
			while (mySerial.available() == 0){}
			padata[i] = mySerial.read();
		DataAvailable = true;
	if ( DataAvailable == true)
		range	= strtok(padata, ",");
		watts	= strtok(NULL, ",");
		va		= strtok(NULL, ",");
		var		= strtok(NULL, ",");
		pf		= strtok(NULL, ",");
		volts	= strtok(NULL, ",");
		amps	= strtok(NULL, ",");
		Serial.print("WATTS: "); Serial.println(watts);
		Serial.print("VA: "); Serial.println(va);
		Serial.print("VAR: "); Serial.println(var);
		Serial.print("PF: "); Serial.println(pf);
		Serial.print("VOLTS: "); Serial.println(volts);
		Serial.print("AMPS: "); Serial.println(amps);
		memset(padata, NULL, 53);
Moderator edit: code tags
I understood Help, power analyzer, project, main feature, appear, serial monitor, and codes. Your translator failed on the rest of the words.
