{HELP} Elevator with 3 floors and buttons
I have this code but the buttons does not work properly with the stepper motor, can anyone help me?
#include <Stepper.h> // incluye libreria stepper
Stepper motor1(2048, 8, 10, 9, 11); // pasos completos
int ActualFloor=1; //definimos la planta actual donde comienza el ascensor
int floor1=1;
int floor2=2;
int floor3=3;
int value1=0;
int value2=0;
int value3=0;
int pasos=0;
motor1.setSpeed(3); // en RPM (valores de 1, 2 o 3 para 28BYJ-48)
pinMode(floor1, INPUT);
pinMode(floor2, INPUT);
pinMode(floor3, INPUT);
Serial.begin(9600); // incializacion de comunicacion serie a 9600 bps
value1 = digitalRead(floor1); //lectura digital de pin
value2 = digitalRead(floor2); //lectura digital de pin
value3 = digitalRead(floor3);
if (plantaActual==1){
if (value2==HIGH){ //lectura digital de pin
motor1.step(-512);
delay(2000);
ActualFloor=2;
if (value3==HIGH){
motor1.step(-1024);
delay(2000);
ActualFloor=3;
motor1.step(0);
delay(2000);
ActualFloor=1;
While you are waiting for the buttons to be pushed, do not use delay(). Read the buttons as fast as you can.
MorganS:
so, the code is correct like that?
Your code does not compile because plantaActual has not been declared
Likely supposed to be ActualFloor - partially completed translation effort?
Can you be more specific?
No. Pay some attention to which pins you can, and which pins you can NOT, use, when using Serial.
