HELP! Error after modifying the GSMShield Library
I am trying this code which I found from a tutorial where he used an Arduino UNO Clone. The code below is to turn on or off an LED on pin 7 after an SMS instruction is received.
In my project I want to use an Arduino Mega 2560 so I needed to modify some lines in the GSM Library for GSM Shield based on SIM900 which it got from "http://www.gsmlib.org/"
Unfortunately I ran into these error after compiling the sketch:
C:\Users\alexi\Downloads\arduino-1.6.7\libraries\GSMSHIELD\HWSerial.cpp: In member function 'size_t HWSerial::print(const __FlashStringHelper*)':
C:\Users\alexi\Downloads\arduino-1.6.7\libraries\GSMSHIELD\HWSerial.cpp:55:9: error: 'prog_char' does not name a type
const prog_char *p = (const prog_char *)ifsh;
In file included from C:\Users\alexi\Downloads\arduino-1.6.7\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from C:\Users\alexi\Downloads\arduino-1.6.7\libraries\GSMSHIELD\HWSerial.h:6,
from C:\Users\alexi\Downloads\arduino-1.6.7\libraries\GSMSHIELD\HWSerial.cpp:1:
C:\Users\alexi\Downloads\arduino-1.6.7\libraries\GSMSHIELD\HWSerial.cpp:58:37: error: 'p' was not declared in this scope
unsigned char c = pgm_read_byte(p++);
exit status 1
Error compiling.
Below is the sample sketch:
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
char number[]="ur cellphone number here";
char message[180];
char pos;
char *p;
void setup() //declaring inputs and outputs
Serial.begin(9600); //initiate gizduino witha baud rate of 9600
pinMode(13, OUTPUT); //output for turning LED ON or OFF
if (gsm.begin(9600)) //condition if gsm is initialized
Serial.println("\nstatus=READY"); //displays "ready" on the serial monitor if gsm is ready
else Serial.println("\nstatus=IDLE"); //otherwise displays "idle" on the serial monitor if gsm is not found
void loop() //looping of the program
pos=sms.IsSMSPresent(SMS_UNREAD); //save to variable if there is an SMS
Serial.println((int)pos); //display position number (a.k.a index) of the message
if((int)pos>0&&(int)pos<=20) //if message from 0-20 is found
Serial.print("Message Received, INBOX="); //display an output on the serial monitor
Serial.println((int)pos); //display the position/index of the message
message[0]='\0'; //display '0' if no messages found
sms.GetSMS((int)pos,number,message,180); //get position/index, number of sender, and text message
Serial.println(message); //display the text on serial monitor
if(strstr(message, "ON")) digitalWrite(13,HIGH); //if message 'ON' is received, LED is ON
if(strstr(message, "OFF")) digitalWrite(13,LOW); //if message 'OFF' is received, LED is OFF
sms.DeleteSMS((int)pos); //after reading, delete SMS
delay(5000); //delay of 5seconds per loop
Does not look like your error is in the sketch but in
I'm not familiar enough to pinpoint the issue, but maybe the library is outdated and contains 'stuff' (prog_char in this case) that worked with older compilers.
Where can I find an updated version of this library.
It is the most updated library I found on the site.
Or maybe I am thinking that the updated Arduino IDE does not comply with the Library I'm using?
If there is no newer library, you have to modify it.
Google for arduino ide prog_char
First hit might help: compile error since IDE 1.5.8
update #2:
  • i'm not using the official shield. i am using breakout board for sim900a i bought from online store.
  • so, i need to connect pins from gsm rx/tx to Serial1 on Arduino Mega.
  • i've checked the code. when I de-comment define MEGA in HWSerial.h and GSM.cpp, the program will now using HWSerial as communication for Arduino Mega and GSM SIM900A.
  • when i further check the code in HWSerial.cpp, it use Serial1 to communicate with GSM. So, pin configuration in GSM.cpp it not used.
  • hope this helps.
update #1:
original post:
same problem here. can't find update for HWSerial.cpp. Please help.
Hi, i was able to solve the issue. modify this line;
to
const char PROGMEM *p = (const char PROGMEM *)ifsh;
