HELP Error Compiling Boards
Arduino: 1.8.20 Hourly Build 2022/04/25 09:33 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi\libfreertos.a(port_common.c.obj):(.literal.main_task+0x14): undefined reference to `app_main'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi\libfreertos.a(port_common.c.obj): in function `main_task':
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port/port_common.c:118: undefined reference to `app_main'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0xc): undefined reference to `Serial'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x54): undefined reference to `HardwareSerial::begin(unsigned long, unsigned int, signed char, signed char, bool, unsigned long, unsigned char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x58): undefined reference to `String::String(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x5c): undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x60): undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x64): undefined reference to `String::String(String const&)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z5setupv+0x68): undefined reference to `pinMode'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x28): undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x30): undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x34): undefined reference to `Print::println(__FlashStringHelper const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x38): undefined reference to `Print::print(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x3c): undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o:(.literal._Z4loopv+0x40): undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `setup()':
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:31: undefined reference to `HardwareSerial::begin(unsigned long, unsigned int, signed char, signed char, bool, unsigned long, unsigned char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:33: undefined reference to `String::String(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:33: undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:34: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:36: undefined reference to `String::String(String const&)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:36: undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:39: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:46: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:55: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:59: undefined reference to `pinMode'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:60: undefined reference to `pinMode'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:61: undefined reference to `pinMode'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:42: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `loop()':
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:65: undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:74: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:77: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:84: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:89: undefined reference to `Print::println(__FlashStringHelper const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:90: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:97: undefined reference to `Print::print(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:97: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:98: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:99: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:100: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:102: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:103: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:104: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:105: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:107: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:108: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:110: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:113: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:114: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:116: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:117: undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:129: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `PString::PString(char*, unsigned int)':
C:\Users\acer\OneDrive\Documents\Arduino\libraries\PString/PString.h:46: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\libraries\PString/PString.h:47: undefined reference to `Print::print(int, int)'
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:136: undefined reference to `Print::println(__FlashStringHelper const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:138: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:153: undefined reference to `Print::print(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:154: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:155: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:157: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:158: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:159: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:160: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:161: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:162: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:163: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:164: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:165: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:166: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:169: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:169: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:174: undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:181: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:183: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:186: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:190: undefined reference to `Print::println(__FlashStringHelper const*)'
C:\Users\acer\OneDrive\Documents\Arduino\libraries\PString/PString.h:46: undefined reference to `Print::println(char const*)'
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:205: undefined reference to `Print::print(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:207: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:208: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:210: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:211: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:214: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:215: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:218: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:218: undefined reference to `Print::print(int, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:219: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:220: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:221: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:222: undefined reference to `Print::print(char)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:223: undefined reference to `Print::print(unsigned char, int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:224: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:226: undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:232: undefined reference to `Print::println(__FlashStringHelper const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `_GLOBAL__sub_I_RTC':
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:240: undefined reference to `String::String(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `__static_initialization_and_destruction_0':
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:242: undefined reference to `String::String(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\sketch_may17a.ino.cpp.o: in function `_GLOBAL__sub_D_RTC':
C:\Users\acer\OneDrive\Documents\Arduino\sketch_may17a/sketch_may17a.ino:246: undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5flushEv+0x0): undefined reference to `delay'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerialC2Ev+0xc): undefined reference to `String::operator=(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.literal._ZN15BluetoothSerial5beginE6Stringb+0x28): undefined reference to `String::operator=(String const&)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::~BluetoothSerial()':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:746: undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::flush()':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:862: undefined reference to `delay'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::BluetoothSerial()':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:784: undefined reference to `String::String(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:786: undefined reference to `String::operator=(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:784: undefined reference to `String::~String()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::begin(String, bool)':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BluetoothSerial.cpp:801: undefined reference to `String::operator=(String const&)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.rodata._ZTV15BluetoothSerial[_ZTV15BluetoothSerial]+0x2c): undefined reference to `Stream::readBytes(char*, unsigned int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o:(.rodata._ZTV15BluetoothSerial[_ZTV15BluetoothSerial]+0x34): undefined reference to `Stream::readString()'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\PString\PString.cpp.o:(.rodata._ZTV7PString[_ZTV7PString]+0x14): undefined reference to `Print::write(unsigned char const*, unsigned int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BTScanResultsSet.cpp.o:(.literal._ZN16BTScanResultsSet4dumpEP5Print+0x10): undefined reference to `Print::printf(char const*, ...)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\BluetoothSerial\BTScanResultsSet.cpp.o: in function `BTScanResultsSet::dump(Print*)':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BTScanResultsSet.cpp:38: undefined reference to `Print::printf(char const*, ...)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BTScanResultsSet.cpp:42: undefined reference to `Print::printf(char const*, ...)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BTScanResultsSet.cpp:44: undefined reference to `Print::printf(char const*, ...)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BluetoothSerial\src/BTScanResultsSet.cpp:46: undefined reference to `Print::println(char const*)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o:(.literal._ZN16Adafruit_Thermal10timeoutSetEm+0x0): undefined reference to `micros'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o: in function `Adafruit_Thermal::timeoutSet(unsigned long)':
C:\Users\acer\OneDrive\Documents\Arduino\libraries\Adafruit_Thermal_Printer_Library/Adafruit_Thermal.cpp:78: undefined reference to `micros'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o: in function `Adafruit_Thermal::timeoutWait()':
C:\Users\acer\OneDrive\Documents\Arduino\libraries\Adafruit_Thermal_Printer_Library/Adafruit_Thermal.cpp:84: undefined reference to `digitalRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\OneDrive\Documents\Arduino\libraries\Adafruit_Thermal_Printer_Library/Adafruit_Thermal.cpp:87: undefined reference to `micros'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o: in function `Adafruit_Thermal::wake()':
C:\Users\acer\OneDrive\Documents\Arduino\libraries\Adafruit_Thermal_Printer_Library/Adafruit_Thermal.cpp:592: undefined reference to `delay'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o: in function `Adafruit_Thermal::begin(unsigned short)':
C:\Users\acer\OneDrive\Documents\Arduino\libraries\Adafruit_Thermal_Printer_Library/Adafruit_Thermal.cpp:198: undefined reference to `pinMode'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Adafruit_Thermal_Printer_Library\Adafruit_Thermal.cpp.o:(.rodata._ZTV16Adafruit_Thermal[_ZTV16Adafruit_Thermal]+0x14): undefined reference to `Print::write(unsigned char const*, unsigned int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire5beginEiij+0x0): undefined reference to `i2cIsInit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire5beginEiij+0x8): undefined reference to `i2cInit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire3endEv+0x0): undefined reference to `i2cSlaveDeinit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire3endEv+0x4): undefined reference to `i2cDeinit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire15endTransmissionEb+0x0): undefined reference to `i2cWrite'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire11requestFromEtjb+0x0): undefined reference to `i2cWriteReadNonStop'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.literal._ZN7TwoWire11requestFromEtjb+0x4): undefined reference to `i2cRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o: in function `TwoWire::begin(int, int, unsigned int)':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:221: undefined reference to `i2cIsInit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:211: undefined reference to `i2cInit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o: in function `TwoWire::end()':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:234: undefined reference to `i2cSlaveDeinit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:248: undefined reference to `i2cIsInit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:239: undefined reference to `i2cDeinit'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o: in function `TwoWire::endTransmission(bool)':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:336: undefined reference to `i2cWrite'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o: in function `TwoWire::requestFrom(unsigned short, unsigned int, bool)':
C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:376: undefined reference to `i2cWriteReadNonStop'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\acer\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.cpp:387: undefined reference to `i2cRead'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.rodata._ZTV7TwoWire[_ZTV7TwoWire]+0x2c): undefined reference to `Stream::readBytes(char*, unsigned int)'
c:/users/acer/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: libraries\Wire\Wire.cpp.o:(.rodata._ZTV7TwoWire[_ZTV7TwoWire]+0x34): undefined reference to `Stream::readString()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board DOIT ESP32 DEVKIT V1.
In general, it is best to use the latest SUPPORTED version of Arduino (1.8.19) unless you are trying to test a fix that is in the latest hourly build.
It looks like something has gone terribly wrong with your installation of either Arduino or the ESP32 support.
Install Arduino IDE 1.8.19 or Arduino IDE 2.0 RC and then install the package core for your board, see Getting Started with the ESP32 Development Board | Random Nerd Tutorials.
Make sure that you use a data USB cable and avoid using USB 3.0 port or USB hub.
Why ?
USB 3.0 port cause some issues. https://support.arduino.cc/hc/en-us/articles/360019546000-My-sketch-compiles-but-does-not-upload-or-the-upload-button-is-grayed-out
That article seems to relate to using the Arduino Create Agent
If the official Arduino advice is not to use a USB hub or USB 3.0 when not using the Create Agent then lots of users will be screwed
