HELP! Error in my code. Controlling Servo Motors using Arduino
Hello,
I'm trying to make one push button a "start" button, and another one a "stop" button. I use "Serial.begin(9600);" but when i try to do "Serial.stop" it doesn't necessarily work lol. I'm very new to coding. if you could help that'd be great! Thanks in advance
coding in MPIDE & error reads :"error: 'class HardwareSerial' has no member named 'stop'" lol
#include <Servo.h>
Servo myservo;
int pos = 0;
int myDirection;
int buttonA=3;
int buttonB=4;
myservo.attach(9);
Serial.println("Enter Direction (L or R);"); //prompt user
pinMode(buttonA,INPUT);
pinMode(buttonB,INPUT);
Serial.stop(9600);
if(Serial.available()); //checks for input
myDirection=Serial.read(); //read the input
}if(myDirection=='L') //go left
if(pos<180){
pos += 1;
else if(myDirection= 'R') //go right
if(pos>0) {
pos-+1;
myservo.write(pos);
delay(15);
got rid of the line
** Serial.stop(9600);**
at the end of the setup function and it now compiles:
#include <Servo.h>
Servo myservo;
int pos = 0;
int myDirection;
int buttonA = 3;
int buttonB = 4;
  myservo.attach(9);
  pinMode(buttonA, INPUT);
  pinMode(buttonB, INPUT);
    if (Serial.available()); //checks for input
      myDirection = Serial.read(); //read the input
    } if (myDirection == 'L') //go left
      if (pos < 180) {
        pos += 1;
    else if (myDirection = 'R') //go right
      if (pos > 0) {
        pos - +1;
    myservo.write(pos);
    delay(15);
how do I set the other button as a "stop" button?
RaynaWolf_:
Your code does not read any buttons so I am not clear what you are trying to do.
What is it that you are trying to start and stop ?
And, I'm not sure why you are trying to use the Serial instance to do it. You should almost certainly be using an instance of the LiquidCrystal class, instead.
