Help Ethernet ENC28J60
I'm having a serious problem with the example code "WebServer" that already comes with the "Ethernet" library, when I run the code, my serial shows "server is at 0.0.0.0" and I can not access the my webserver via local network, I'm using the ENC28J60 module, the connections made are as follows (I'm using an ATMega)
The default IP of my modem is 192.168.0.1, as you can see I changed the IP of the code ("WebServer") to 192.168.0.25, but it still did not work. (IP 25 is not interfering with any other IP).
What's going on? Strange that I downloaded that "Ethercard-master" library and when I use the Notifymyandroid example "it works fine...
I am using the following code:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0, 25);
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
if (client) {
Serial.println("new client");
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
} else if (c != '\r') {
currentLineIsBlank = false;
delay(1);
client.stop();
Serial.println("client disconnected");
You cannot use the Ethernet library with the ENC28J60. Use the EtherCard or UIPEthernet libraries for that chip.
pylon:
Good! Didn't know about that, but I still have a problem, it's not the same (I believe), I tried the code of ethercard library, the code is:
// Demo using DHCP and DNS to perform a web client request.
// 2011-06-08 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
const char website[] PROGMEM = "www.google.com";
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
  Serial.println(">>>");
  Ethernet::buffer[off+300] = 0;
  Serial.print((const char*) Ethernet::buffer + off);
  Serial.println("...");
void setup () {
  Serial.begin(57600);
  Serial.println(F("\n[webClient]"));
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println(F("Failed to access Ethernet controller"));
  if (!ether.dhcpSetup())
    Serial.println(F("DHCP failed"));
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
#if 1
  // use DNS to resolve the website's IP address
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
#elif 2
  // if website is a string containing an IP address instead of a domain name,
  // then use it directly. Note: the string can not be in PROGMEM.
  char websiteIP[] = "192.168.0.15";
  ether.parseIp(ether.hisip, websiteIP);
#else
  // or provide a numeric IP address instead of a string
  byte hisip[] = { 192,168,0,15 };
  ether.copyIp(ether.hisip, hisip);
#endif
  ether.printIp("SRV: ", ether.hisip);
void loop () {
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer) {
    timer = millis() + 5000;
    Serial.print("<<< REQ ");
    ether.browseUrl(PSTR("/foo/"), "bar", website, my_callback);
And the serial monitor is showing this to me:
[webClient]
IP:  192.168.0.15
GW:  192.168.0.1
DNS: 187.123.29.61
SRV: 74.125.141.103
<<< REQ >>>
HTTP/1.0 404 Not Found
Content-Type: text/html; charset=UTF-8
Content-Length: 1568
Date: Wed, 08 Feb 2017 21:01:47 GMT
<!DOCTYPE html>
<html lang=en>
  <meta charset=utf-8>
  <meta name=viewport content="initial-scale=1, minimum-scale=1, width=device-width">
  <title>Error 404 (Not Found)!!1</...
The only problem you have is that you don't know what you're doing :-).
That program called the URL "http://www.google.com/foo/bar", so the answer that this is not found is probably correct. Change that stuff to an existing URL and you probably get an actual web page back.
