HELP exit status 1 expected unqualified-id before 'for'
here is my code, it gives me a error and i can’t find how to solve it
#include <Wire.h>
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
//#define LiquidCrystal_I2C
LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27,16,2);
DHT dht(DHTPIN, DHTTYPE);
int GREEN = 8;
int AMBER = 9;
int RED = 10;
dht.begin();
pinMode (GREEN, OUTPUT);
pinMode (AMBER, OUTPUT);
pinMode (RED, OUTPUT);
dht.begin();
lcd.begin(16, 2);
Wire.begin();
while (!Serial);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println(“Scanning…”);
nDevices = 0;}
for (address = 1; address < 127; address++ ) /The error is here ← /
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print(“I2C device found at address 0x”);}
if (address < 16){
Serial.print(“0”);
Serial.print(address, HEX);
Serial.println(" !");
nDevices++;
else if (error == 4) {
Serial.print(“Unknown error at address 0x”);}
if (address < 16){
Serial.print(“0”);
Serial.println(address, HEX);
if (nDevices == 0)
Serial.println(“No I2C devices found\n”);
Serial.println(“done\n”);
delay(5000);
if (t <= 20) {
digitalWrite (GREEN, HIGH);
digitalWrite (AMBER, LOW);
digitalWrite (RED, LOW);
else if (t <= 30) {
digitalWrite (GREEN, LOW);
digitalWrite (AMBER, HIGH);
else {
digitalWrite (RED, HIGH);
The problem is that you finished loop() with a } just before that error line. So it and everything following are not inside any function and having code outside a function is not allowed.
Try using Ctrl-T (Auto Format) and check that your braces {} are paired correctly.
Steve
