Help!!! Exit status 1
I bought the robot with the arduino board and when I tried to upload the code I kept getting messages that "exit status 1
Error compiling for board Arduino/Genuino Uno.
". Can someone explain what the situation might be and what I am supposed to do thanks a lot.
Here comes the code:
(code tags added by Moderator - please use them in future posts, see the </> button)
#include <IRremote.h>//包含红外库
int RECV_PIN = A4;//端口声明
IRrecv irrecv(RECV_PIN);
decode_results results;//结构声明
int on = 0;//标志位
unsigned long last = millis();
long run_car = 0x00FF18E7;//按键2
long back_car = 0x00FF4AB5;//按键8
long left_car = 0x00FF10EF;//按键4
long right_car = 0x00FF5AA5;//按键6
long stop_car = 0x00FF38C7;//按键5
long left_turn = 0x00ff30CF;//按键1
long right_turn = 0x00FF7A85;//按键3
int Left_motor_back=9;     //左电机后退(IN1)
int Left_motor_go=5;     //左电机前进(IN2)
int Right_motor_go=6;    // 右电机前进(IN3)
int Right_motor_back=10;    // 右电机后退(IN4)
 //初始化电机驱动IO为输出方式
 pinMode(Left_motor_go,OUTPUT); // PIN 8 (PWM)
 pinMode(Left_motor_back,OUTPUT); // PIN 9 (PWM)
 pinMode(Right_motor_go,OUTPUT);// PIN 10 (PWM)
 pinMode(Right_motor_back,OUTPUT);// PIN 11 (PWM)
 pinMode(13, OUTPUT);////端口模式,输出
 Serial.begin(9600); //波特率9600
 irrecv.enableIRIn(); // Start the receiver
void run()     // 前进
 digitalWrite(Right_motor_go,HIGH);  // 右电机前进
 digitalWrite(Right_motor_back,LOW);
 //analogWrite(Right_motor_go,200);//PWM比例0~255调速,左右轮差异略增减
 //analogWrite(Right_motor_back,0);
 digitalWrite(Left_motor_go,HIGH);  // 左电机前进
 digitalWrite(Left_motor_back,LOW);
 //analogWrite(Left_motor_go,200);//PWM比例0~255调速,左右轮差异略增减
 //analogWrite(Left_motor_back,0);
 //delay(time * 100);   //执行时间,可以调整
void brake()         //刹车,停车
 digitalWrite(Right_motor_go,LOW);
 digitalWrite(Left_motor_go,LOW);
 //delay(time * 100);//执行时间,可以调整
void left()         //左转(左轮不动,右轮前进)
 //analogWrite(Right_motor_back,0);//PWM比例0~255调速
 digitalWrite(Left_motor_go,LOW);   //左轮不动
 //analogWrite(Left_motor_go,0);
 //analogWrite(Left_motor_back,0);//PWM比例0~255调速
void spin_left()         //左转(左轮后退,右轮前进)
 digitalWrite(Left_motor_go,LOW);   //左轮后退
 digitalWrite(Left_motor_back,HIGH);
 //analogWrite(Left_motor_back,200);//PWM比例0~255调速
void right()        //右转(右轮不动,左轮前进)
 digitalWrite(Right_motor_go,LOW);   //右电机不动
 //analogWrite(Right_motor_go,0);
 digitalWrite(Left_motor_go,HIGH);//左电机前进
void spin_right()        //右转(右轮后退,左轮前进)
 digitalWrite(Right_motor_go,LOW);   //右电机后退
 digitalWrite(Right_motor_back,HIGH);
 //analogWrite(Right_motor_back,200);//PWM比例0~255调速
void back()          //后退
 digitalWrite(Right_motor_go,LOW);  //右轮后退
 //analogWrite(Right_motor_back,150);//PWM比例0~255调速
 //analogWrite(Left_motor_back,150);//PWM比例0~255调速
void dump(decode_results *results)
 int count = results->rawlen;
 if (results->decode_type == UNKNOWN)
   //Serial.println("Could not decode message");
   brake();
//串口打印,调试时可以打开,实际运行中会影响反应速度,建议屏蔽
   if (results->decode_type == NEC)
     Serial.print("Decoded NEC: ");
   else if (results->decode_type == SONY)
     Serial.print("Decoded SONY: ");
   else if (results->decode_type == RC5)
     Serial.print("Decoded RC5: ");
   else if (results->decode_type == RC6)
     Serial.print("Decoded RC6: ");
   Serial.print(results->value, HEX);
   Serial.print(" (");
   Serial.print(results->bits, DEC);
   Serial.println(" bits)");
 Serial.print("Raw (");
 Serial.print(count, DEC);
 Serial.print("): ");
 for (int i = 0; i < count; i++)
   if ((i % 2) == 1)
     Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
     Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
   Serial.print(" ");
 Serial.println("");
 if (irrecv.decode(&results)) //调用库函数:解码
   // If it's been at least 1/4 second since the last
   // IR received, toggle the relay
   if (millis() - last > 250) //确定接收到信号
     on = !on;//标志位置反
     digitalWrite(13, on ? HIGH : LOW);//板子上接收到信号闪烁一下led
     dump(&results);//解码红外信号
   if (results.value == run_car )//按键2
     run();//前进
   if (results.value == back_car )//按键8
     back();//后退
   if (results.value == left_car )//按键4
     left();//左转
   if (results.value == right_car )//按键6
     right();//右转
   if (results.value == stop_car )//按键5
     brake();//停车
   if (results.value == left_turn )//按键1
     spin_left();//左旋转
   if (results.value == right_turn )//按键3
     spin_right();//右旋转
   last = millis();
   irrecv.resume(); // Receive the next value
If you find that there are any problems with the code please point out and provide any directions to help me fix it, I know nothing about programming :slight_smile:
Scroll up the list of errors and tell us what the first one was.
Please post the whole error message or messages.
Please edit your post and put code tags (</>) around your code to stop it being mangled by the forum software. I assume that latter parts of your code are not meant to be in italics.
Yes, copy/paste the error message(s) you are seeing.
Starting at this line in dump() : if (results->decode_type == UNKNOWN)
Is -> a valid operator? What does it do?
The error message is as follow:
/Applications/Arduino.app/Contents/Java/libraries/RobotIRremote/src/IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope int RECV_PIN = TKD2; // the pin the IR receiver is connected to ^ exit status 1 Error compiling for board Arduino/Genuino Uno.
CrossRoads: Yes, copy/paste the error message(s) you are seeing.
Yes it is a valid operator. Its what you use to get a member field when you have a pointer to an object. Same as (*object).field
That TKD2 error came up recently in another topic as well. Try a search for that topic and see if there was a solution found.
Thanks for the -> explanation. Hadn't seen that before.
Unfortunately i am still not able to solve the problem after reviewing the other forum coz the code is completely different. Anyone mind if they could check my code to see whether there is something wrong with it?
/Applications/Arduino.app/Contents/Java/libraries/RobotIRremote/src/IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scopeThis looks familiar from posts that I have seen in threads that I was not involved in.
It has to do with the fact that the Arduino robot has pins labelled TK and you are compiling for a Uno. A suggested solution is to take the RobotIRremote library out of the Arduino libraries folder to force the compiler to use the original IR library. Do this at your own risk and save the library in case you need to put it back. Stop/start the IDE after removing the library.
Delete the file that is causing the problem, unless you have an Arduino robot.
So I deleted the file and it compiled fine, but when I upload it to the board another problem showed up:
avrdude: ser_open(): can't open device "/dev/cu.Bluetooth-Modem": Resource busy ioctl("TIOCMGET"): Inappropriate ioctl for device Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
So why didn't you? If you had, you'd find that whining in the wrong section of the forum is way down on the list. You'd also have ALL of the answers needed to help you.
For instance, you'd KNOW that you needed to ditch all the bluetooth crap and hard-wire the Arduino to the PC. The word bluetooth should be nowhere in the name of the port that the Arduino is connected to.
