HELP: Externally powering Arduino Micro
Help! I'm a complete and utter idiot when it comes to the Micro, I've never worked with it before. I want to make sure I don't fry my new board right away and I can't find an answer to this question.
When I hook up the positive lead of a 9 volt battery to the VI pin, do I need to hook up the negative lead of the battery to any pin and if so which one?
Sorry for my lack of knowledge I just really don't want to fry my new board after I immediately killed one last time I tried to use one of the smaller boards.
Thank you so much, -Ilsol
Is the VI connected to the on board regulator?
Yes, the VI pin is the equivalent of the VIN pin on most Arduino boards.
Look at this: http://www.qrg.northwestern.edu/projects/vss/docs/power/2-how-do-batteries-work.html
Current flows - a flow is impossible with one wire. The current flows into the Arduino, and out of one of the GND-pin, which goes to battery negative.
A 9V PP3-block-battery is a very bad choice for Arduino. Search the forum for info on this.
// Per.
