Help Fan Control
Hello,
I need help. I try to control my fan.
Description:
Water Temp should be 24 - 26 degries
if Watertemp rise up over 26 degries, the fan should turn on.
with the PWM signal, I want to control the speed.
26 -27 degries 50% Ratio Speed
27-28 dgries , 75% Ratio speed
over 29 degries, 100% ratio speed.
I have started
like this:
sensors.requestTemperatures();
float TempWatter = sensors.getTempCByIndex(0);
Serial.print(“Wassertemperatur:”);
Serial.println(TempWatter);
if (TempWatter<26){
digitalWrite(Heater, LOW);
Serial.println(“Fan”);
Serial.println(“Off”);
if(TempWatter>29,1){
digitalWrite(Heater, HIGH);
Serial.println(“On”);
byte tgt1 = 255;
getPwm(tgt1);
Serial.print(“Ziel1: “);
Serial.print(map(tgt1, 0, 255, 0, 100));
Serial.println(’%’);
Serial.println(”-----”);
analogWrite(9, tgt1);
if(TempWatter<29,1&&TempWatter>27){
byte tgt1 = 192;
getPwm(tgt1);
if(TempWatter>26,1&&TempWatter<27){
byte tgt1 = 128;
getPwm(tgt1);
Please post your entire sketch using code blocks.
You have to use the decimal point '.' in floating point constants
Hello,
here ist the INO file with all content.
the characters “,” i have not changed yet.
BR
Romai
L_ftersteuerung.ino (2.03 KB)
I have changed the "," to "." and it works now. Have someone a better idea, how I can make the script smarter?
You have three almost identical sections of code like this:
    Serial.println("Fan");
    Serial.println("On");
    byte tgt1 = 128;
    getPwm(tgt1);
    Serial.print("Ziel1: ");
    Serial.println('%');
    Serial.println("-----");
Where the only thing that differs is the value for tgt1. You could write a function that does all that taking a parameter of type byte. That would make your sketch shorter and simpler.
Hey thanks guys,
I am not so familar. how I can do this?
wildbill:
romai2050:
Have a look at this, as a start.
Hey guys,
thanks so lot, I have completed my program with function it works fine.
