help finding amplifier
Hi All,
i am doing a project to monitor traffic using magnetic sensor.
sensor: HMC1001. output voltage +/- 43microV
Arduino Board: Arduino Nano (input 5V)
i am looking for an amplifier to connected in between sensor and arduino nano.
may i know what could be the possible amplifier model? preferably an instrumentation amplifier and with low pass filter
many thanks!!!
i am looking for an instrumentation amplifier to connect in between HMC1001 sensor and Arduino Nano board.
HMC1001 output is around +/- 43microV
Arduino Nano input is around 5V
kindly advise on the amplifiers that could be suitable to use.
many thanks!!!!
Hello 63611,
Welcome.
I am not familiar with the HMC1001 so I looked at the data sheet. From a quick reading of the data sheet it seems that the output is of the order of millivolts not microvolts.
Have you read page 11 of the data sheet, which has recommended amplifiers and circuits?
It helps to post more information, such as a link to the data sheet.
Some information here
http://www.skillbank.co.uk/arduino/measure3.htm
the AD623 is one you could consider
Have you considered the amplifiers shown in the datasheet's typical application circuits?
Yes, HMC1001 is about 3.2mV/V/gauss, so about 1 to 2 mV/V for Earth's ambient magnetic field, so
given 5V excitation about 5 to 10mV full-scale as a compass - any decent instrumentation amp will
work with this as its a straight-forward low-impedance Wheatstone bridge circuit. I suspect the
HX711 (inst. amp + ADC) would work for instance.
I looked at the circuits in the datasheet, just a rail-to-rail opamp of no particular precision...
This looks a lot like another thread in Sensors.
Very much like a thread in General Electronics., but different name.
Hi all,
many thanks for reply.
i have attached datasheet and my output calculation is based on second attachment(page 4 first graph).
(20m+15m)/40.51%= 43.75 MicroV. please correct me if my calculation is wrong.
may i know how can i calculate the minimum output voltage from HMC1001?
i am looking for a amplifier that has low noise level around 1 Hz.
and also use low pass filter between sensor and amplifier input t0 suppress noise at high frequency
HMC1001.pdf (188 KB)
luofan:
Your calculation does not properly use units. Also, the (20mV+15mV)/4Oe is the absolute value of the slopes of the two lines, but the source of the (0.5*1%)Oe is not obvious (to me).
how do i find the minimum output voltage from sensor?
Duplicate topics merged
@luofan and @636ll have the same IP and email addresses
The 6311 account has been banned and luofan can count himself lucky not to have been banned as well
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
