OK, so this is my first real project. It's a binary clock -- not BCD, mind you, but "true" binary. So, the first bit is half days, the second bit is quarter days, then eighths, etc. Here's an example: Abulsme True Binary Time
I set this up on a breadboard with 10 LEDs but would like eventually to expand it to a 4x4 matrix with a demuxer.
I thought that this would be pretty straight-forward, but the clock seems to be gaining about 6min/day. I've poked around on the forums here and heard a that this is normal because the Uno uses a ceramic rather than a crystal resonator. So, there are two ways to go about fixing it: Hardware -- get a RTC with a crystal resonator ; or Software -- measure the inaccuracy and compensate for it in the code.
Which route should I take? Would I even be able to use a RTC with this thing since it doesn't use HH:MM:SS? Or if I go the software route, ??? Could someone talk me through that? And maybe dumb it down a little for a novice?
Here's my code. Thanks!
const int LED1 = 4;
const int LED2 = 5;
const int LED3 = 6;
const int LED4 = 7;
const int LED5 = 8;
const int LED6 = 9;
const int LED7 = 10;
const int LED8 = 11;
const int LED9 = 12;
const int LED10 = 13;
int LEDState1 = LOW;
int LEDState2 = LOW;
int LEDState3 = LOW;
int LEDState4 = LOW;
int LEDState5 = LOW;
int LEDState6 = LOW;
int LEDState7 = LOW;
int LEDState8 = LOW;
int LEDState9 = LOW;
int LEDState10 = LOW;
long previousMillis1 = 0;
long previousMillis2 = 0;
long previousMillis3 = 0;
long previousMillis4 = 0;
long previousMillis5 = 0;
long previousMillis6 = 0;
long previousMillis7 = 0;
long previousMillis8 = 0;
long previousMillis9 = 0;
long previousMillis10 = 0;
long interval1 = 43200000;
long interval2 = 21600000;
long interval3 = 10800000;
long interval4 = 5400000;
long interval5 = 2700000;
long interval6 = 1350000;
long interval7 = 675000;
long interval8 = 337500;
long interval9 = 168750;
long interval10 = 84375;
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(LED9, OUTPUT);
pinMode(LED10, OUTPUT);
if(currentMillis - previousMillis1 > interval1) {
previousMillis1 = currentMillis;
if (LEDState1 == LOW)
LEDState1 = HIGH;
LEDState1 = LOW;
digitalWrite(LED1, LEDState1);
if(currentMillis - previousMillis2 > interval2) {
previousMillis2 = currentMillis;
if (LEDState2 == LOW)
LEDState2 = HIGH;
LEDState2 = LOW;
digitalWrite(LED2, LEDState2);
if(currentMillis - previousMillis3 > interval3) {
previousMillis3 = currentMillis;
if (LEDState3 == LOW)
LEDState3 = HIGH;
LEDState3 = LOW;
digitalWrite(LED3, LEDState3);
if(currentMillis - previousMillis4 > interval4) {
previousMillis4 = currentMillis;
if (LEDState4 == LOW)
LEDState4 = HIGH;
LEDState4 = LOW;
digitalWrite(LED4, LEDState4);
if(currentMillis - previousMillis5 > interval5) {
previousMillis5 = currentMillis;
if (LEDState5 == LOW)
LEDState5 = HIGH;
LEDState5 = LOW;
digitalWrite(LED5, LEDState5);
if(currentMillis - previousMillis6 > interval6) {
previousMillis6 = currentMillis;
if (LEDState6 == LOW)
LEDState6 = HIGH;
LEDState6 = LOW;
digitalWrite(LED6, LEDState6);
if(currentMillis - previousMillis7 > interval7) {
previousMillis7 = currentMillis;
if (LEDState7 == LOW)
LEDState7 = HIGH;
LEDState7 = LOW;
digitalWrite(LED7, LEDState7);
if(currentMillis - previousMillis8 > interval8) {
previousMillis8 = currentMillis;
if (LEDState8 == LOW)
LEDState8 = HIGH;
LEDState8 = LOW;
digitalWrite(LED8, LEDState8);
if(currentMillis - previousMillis9 > interval9) {
previousMillis9 = currentMillis;
if (LEDState9 == LOW)
LEDState9 = HIGH;
LEDState9 = LOW;
digitalWrite(LED9, LEDState9);
if(currentMillis - previousMillis10 > interval10) {
previousMillis10 = currentMillis;
if (LEDState10 == LOW)
LEDState10 = HIGH;
LEDState10 = LOW;
digitalWrite(LED10, LEDState10);
