I'm trying to attach a Myoware EMG sensor and I'm using this code to activate it. Whenever I try to run it, however, it gives me this error message:
Compilation error: Error: 2 UNKNOWN: exit status 1
Can anyone help me?
My code:
#include <Servo.h>
Servo myservo;
const int threshValue = 250;
myServo.attatch(9);
int value = analogRead(A3);
if(value < threshValue)
myServo.writeMicroseconds(800);
myServo.writeMicroseconds(2500);
Your code is incomplete.
void loop ()
You also spelled attach wrong.
Please remember to use code tags when posting code, and post ALL of the error messages
@cmherman74, your topic has been moved to a more suitable location on the forum.
Can you take a bit of time to read How to get the best out of this forum and next edit your post and apply to your post what you've read / learned about code tags. Thank you.
Your code corrected, formatted with the IDE auto format tool and posted properly in code tags (</>). See comments.
#include <Servo.h>
Servo myServo; // ******* changed from myservo
// ******* C++ is case sensitive
myServo.attach(9); // ******* attatch bad spelling
{ // *** added
if (value < threshValue)
} // *** added
Why are you using a beta version of the IDE; you will probably get more useful information from the IDE if you use the standard 1.8.x version.
// Edit
I've just installed the 2.0 Beta and forced an error in the bareminimum sketch; the output that I get
c:\Users\sterretje\AppData\Local\Temp\.arduinoIDE-unsaved2021521-1040-lvrli7.xtq5l\BareMinimum\BareMinimum.ino: In function 'void loop()':
c:\Users\sterretje\AppData\Local\Temp\.arduinoIDE-unsaved2021521-1040-lvrli7.xtq5l\BareMinimum\BareMinimum.ino:6:13: error: expected '}' at end of input
So there is more info available.
