Help fo RFID 522 module
hi,
I try to make power cut circuit by RFID module working only if IFRD card still put on module, (by make Pin 5 High)
How to get code to make pin 5 low when remove the card or tag from RFID module
SoftwareSerial mySerial(2, 3);
#include <Wire.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 8
#define Unlock 5
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
while (!Serial);
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
pinMode(Unlock, OUTPUT);
digitalWrite(Unlock,HIGH);
lcd.begin();
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
if ( ! mfrc522.PICC_ReadCardSerial())
return;
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte < 0x10 ? " 0" : " ");
_ Serial.print(mfrc522.uid.uidByte*, HEX);_
_ content.concat(String(mfrc522.uid.uidByte < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte, HEX));
Serial.println();*_
* content.toUpperCase();*
if ((content.substring(1) == "D2 D8 66 A3")||(content.substring(1) == "76 1D 62 A3")||(content.substring(1) == "71 C5 7D 83")||(content.substring(1) == "56 F2 7D 83")||(content.substring(1) == "D3 0D 72 91")||(content.substring(1) == "FA DD C3 CE")) //change here the UID of the card/cards that you want to give access
* digitalWrite(Unlock,LOW);*
How to get code to make pin 5 low when take away the card or tag from RFID module
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f, 16, 2);
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 8
#define Unlock 5
while (!Serial);
lcd.begin();
return;
// Select one of the cards
return;
//Show UID on serial monitor
String content= "";
byte letter;
Serial.println();*_
* if ((content.substring(1) == "D2 D8 66 A3")||(content.substring(1) == "76 1D 62 A3")||(content.substring(1) == "71 C5 7D 83")||(content.substring(1) == "56 F2 7D 83")||(content.substring(1) == "D3 0D 72 91")||(content.substring(1) == "FA DD C3 CE")) //change here the UID of the card/cards that you want to give access*
Do not double post.
Please use code tags when posting code, as described in "How to use this forum". Do not double post.
jremington:
Do not double post.
sorry i try to post as question put can not delet the original
Look at what happens in loop().
    return;
You need to look at what that function does, to determine when a card was removed and replaced. It knows that the card it is now reading is, or is not, the same as the one it was giving data for the last time you asked.
PaulS:
    return;
the function is stop read from card if card take away , hwo to add this cass code when the card take away
What do those if statements in the beginning of loop() do? Maybe you can do something there?
sterretje:
i want code in case stop read from card if card take away to do some thing by (if condition) like
if ( " case serial stop read ")
