Help for a program with buttons and leds
Hi guys,
I'd like to have your help because I have a program that should control 5 leds (pompa1, pompa2, pompa3, pompa4, valvola) using 3 bottons (interruttore,cronotermostato,orologio). I'll attach the program that I've done because there may be some errors that I can't see. I hope you can be helpful for me.
Thank you for your attention.
sketch_jul11a.ino (1.83 KB)
Instead of,
   buttonState = digitalRead(interruttore);//Legge lo stato del bottone
  if (interruttore == HIGH)
put if (buttonState == HIGH)
I tryed to do that, but it seems like the program doesn't care the "if" instruction and only do the "else".
Infact no matter what I do, arduino only do that.
why?
Thank you very much
AnalogReadSerial.ino (181 Bytes)
you need to modify else condition also.
since you had put a ';' at the end of else.. so that else condition terminated there.
use
     digitalWrite (pompa2,HIGH);
     digitalWrite (pompa4,HIGH);
     digitalWrite (pompa3,HIGH);
     digitalWrite (pompa1,LOW);
     digitalWrite (valvola,LOW);
it may solve your issue. your code has many bugs.. use below code as a reference..
  const int interruttore = 9;
  int pompa1 = 2;
  int pompa2 = 3;
  int pompa3 = 4;
  int pompa4 = 5;
  const  int cronotermostato = 12;
  const int orologio = 11;
  int valvola = 8;
  byte buttonState1 = LOW;
  byte buttonState2 = LOW;
  byte buttonState3 = LOW;
void setup ()
  pinMode(interruttore,INPUT);
  pinMode(pompa1,OUTPUT);
  pinMode(pompa2,OUTPUT);
  pinMode(pompa3,OUTPUT);
  pinMode(pompa4,OUTPUT);
  pinMode(cronotermostato,INPUT);
  pinMode(orologio,INPUT);
  pinMode(valvola,OUTPUT);
void loop ()
   buttonState1 = digitalRead(interruttore);//Legge lo stato del bottone
  if (buttonState1 == HIGH)
         buttonState1 == LOW;
         buttonState2 = digitalRead(cronotermostato);
         if (buttonState2 == HIGH)
          digitalWrite ( pompa2, HIGH );
          digitalWrite ( pompa4, HIGH );
          digitalWrite ( pompa2, LOW );
          digitalWrite ( pompa4, LOW );
           buttonState3 = digitalRead(orologio);//Legge lo stato del bottone
          if (buttonState3 == HIGH)
            digitalWrite ( pompa3, HIGH );
            digitalWrite ( pompa3, LOW );
          if ( pompa2==HIGH || pompa4==HIGH)
              digitalWrite (pompa1,HIGH);
              digitalWrite (valvola,HIGH);
Thank You so much for your help!!!!!! I've just finished the program :slight_smile:
