devilesence:
the site says :Upload to Arduino device the ModBus RTU protocol..
when i put it in sketchbook and compile it says :As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
how to upload the protocol ?
...now i have uploaded the protocol by the arduino 0023 version ..but the server still wont recognise it..
How much information this contains? I mean, if you put yourself in other peoples position, how would this look like to you?
Try more text, less smileys.
Yep. Looks like the Arduino implementation was a proof-of-concept that didn't hold someone's interest long enough to extend the functionality to meaningful levels.
@garryp , i thought many people must have used this scada software ,as it is the only one that supports arduino.. people who have used it will get it easily, to what i mean .. i've qouted it from the installation guide ..
devilesence:
What if you turn this assumption upside down? Maybe many "scada software" users are using Arduinos, but how many of them are there, I have no idea...?
But, could you give a link to that software? Maybe the answer lies over there, I'm interested if it has something to do with this: http://en.wikipedia.org/wiki/SCADA
with IDE version 1.0 of arduino some implementaion changed. Helpful for me:
shurely in this forum there are similar information - google showed me this at first.
There you will find the section:
The BYTE keyword is no longer supported. Change:
Serial.print(val, BYTE)
To:
Serial.write(val); //sends as char
Just do it within the sketch
for (i = 0; i < string_length; i++) {
Serial.write(query*);* … and it will work for a short time … currently there seems to be a licensproblem within this software. I just startet working on it. Cheers Frank (Just one year to late …)
