Help for analog signal on Arduino
I have an Arduino Leonardo and I need to connect an analog signal to the AD port.
The analog signal comes from an external device.
The device signal has two pins: GND and CONTROL.
The signal basically has two low noise states.
CONTROL - GND
1.1 Volts
0 volts
My program does the following:
When:
CONTROL - GND PROGRAM
1.1 Volts Runs A
0 Volts Runs B
My question is the connection of this signal (device) to the AD port of the Arduino.
In my assembly I connect Device GND to Arduino GND and CONTROL to Arduino A0 port directly.
Would this be the correct way?
Should there be a few more components to protect the circuits or even have an AD port read with less chance of errors?
Att,
Alysson
Assuming the wire lengths are reasonably short & tidy, those connections shoukd be ok.
The next question is : should (a) and (b) run continuously during the high/low states, or only when the input state changes.
Just when input state changes. This signal looks like a "push-button".
This could be a function that acts like a digitalRead().
  read an analogue input pin and return LOW or HIGH
  In:
    pin to read
  Returns:
    LOW if signal below 500 mV, else HIGH
uint8_t readUnknownDevice(uint8_t pin)
  // read the ananlog input
  int x = analogRead(pin);
  if (x < 100)
    // if reading below roughly 500 mV, return LOW
    return LOW;
    // if reading not below roughly 500 mV, return HIGH
    return HIGH;
You can use it e.g. like
  Serial.print(F("Unknown device signal "));
  Serial.println(readUnknownDevice(A0) == LOW ? "LOW" : "HIGH");
I'll leave the state change detection to you. It can be implemented in loop() or in another function that you can call from loop().
Code compiles, not tested.
