Help for building my first project
Hi there, i'm building my first robot with my father and i request your guidance. Please take note that i have small knowledge of electronics. :~
I would like to build a robot that could lift some object of lets say a max of 5 kg .
would i need a
arduino uno board
arduino motor shield
some servo
and a motor .
Am i correct ?
ps: is there a way to know how much can a motor lift at what speed?
Thanks for all your help ! :slight_smile:
sounds like a fun but pretty challenging first-robot project!
this is a good, not-too-technical, summary of what you'll need to know:
http://wiki.goodrobot.com/wiki/Servos
That will be a large bot with probably significant $$$ investment. You probably need to use google and research various robotic sites, bot sellers and such to get a good idea of what you want to make.
thanks for you help ! .
Well actually im only trying to lift 2-3 monitors from the ground to a level. here are the brand Samsung SyncMasterB2030
They each weight around 4.1 kg.
You may want to check the tv lifts at the below site.
