Okey i hope that this will help someone, i did read many topics for this and what did help me ![]()
If you have mega or leonard
http://arduino.cc/en/Guide/GSMShieldLeonardoMega -
Add external power supply
In some networks you will need band management
Band Management
This sketch, for the Arduino GSM shield, checks the band
currently configured in the modem and allows you to change
it.
Please check http://www.worldtimezone.com/gsm.html
Usual configurations:
Europe, Africa, Middle East: E-GSM(900)+DCS(1800)
USA, Canada, South America: GSM(850)+PCS(1900)
Mexico: PCS(1900)
Brazil: GSM(850)+E-GSM(900)+DCS(1800)+PCS(1900)
Circuit:
* GSM shield
created 12 June 2012
by Javier Zorzano, Scott Fitzgerald
This example is in the public domain.
// libraries
#include <GSM.h>
// initialize the library instance
GSMBand band;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// Beginning the band manager restarts the modem
Serial.println("Restarting modem...");
band.begin();
Serial.println("Modem restarted.");
// Get current band
String bandName = band.getBand(); // Get and print band name
Serial.print("Current band:");
Serial.println(bandName);
Serial.println("Want to change the band you’re on?");
String newBandName;
newBandName = askUser();
// Tell the user what we are about to do…
Serial.print("\nConfiguring band ");
Serial.println(newBandName);
// Change the band
boolean operationSuccess;
operationSuccess = band.setBand(newBandName);
// Tell the user if the operation was OK
if (operationSuccess)
Serial.println("Success");
Serial.println("Error while changing band");
while (true);
// This function offers the user different options
// through the Serial interface
// The user selects one
String askUser()
String newBand;
Serial.println("Select band:");
// Print the different options
Serial.println("1 : E-GSM(900)");
Serial.println("2 : DCS(1800)");
Serial.println("3 : PCS(1900)");
Serial.println("4 : E-GSM(900)+DCS(1800) ex: Europe");
Serial.println("5 : GSM(850)+PCS(1900) Ex: USA, South Am.");
Serial.println("6 : GSM(850)+E-GSM(900)+DCS(1800)+PCS(1900)");
// Empty the incoming buffer
while (Serial.available())
Serial.read();
// Wait for an answer, just look at the first character
while (!Serial.available());
char c = Serial.read();
if (c == '1')
newBand = GSM_MODE_EGSM;
else if (c == '2')
newBand = GSM_MODE_DCS;
else if (c == '3')
newBand = GSM_MODE_PCS;
else if (c == '4')
newBand = GSM_MODE_EGSM_DCS;
else if (c == '5')
newBand = GSM_MODE_GSM850_PCS;
else if (c == '6')
newBand = GSM_MODE_GSM850_EGSM_DCS_PCS;
newBand = "GSM_MODE_UNDEFINED";
return newBand;
I did try Arduino 1.0.6 there was something that did not work
Try Arduino 1.5.8 BETA -
Most importantly, try something easy example: GSM Scan Networks, so you can see if it works before you'll try anything complicated
GSM Scan Networks
This example prints out the IMEI number of the modem,
then checks to see if it's connected to a carrier. If so,
it prints the phone number associated with the card.
Then it scans for nearby networks and prints out their signal strengths.
Circuit:
* GSM shield
* SIM card
Created 8 Mar 2012
by Tom Igoe, implemented by Javier Carazo
Modified 4 Feb 2013
by Scott Fitzgerald
http://arduino.cc/en/Tutorial/GSMToolsGsmScanNetworks
This example code is part of the public domain
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER "0000"
GSM gsmAccess; // include a 'true' parameter to enable debugging
GSMScanner scannerNetworks;
GSMModem modemTest;
// Save data variables
String IMEI = "";
// serial monitor result messages
String errortext = "ERROR";
while (!Serial) {
Serial.println("GSM networks scanner");
scannerNetworks.begin();
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected)
if (gsmAccess.begin(PINNUMBER) == GSM_READY)
notConnected = false;
Serial.println("Not connected");
// get modem parameters
// IMEI, modem unique identifier
Serial.print("Modem IMEI: ");
IMEI = modemTest.getIMEI();
IMEI.replace("\n", "");
if (IMEI != NULL)
Serial.println(IMEI);
// scan for existing networks, displays a list of networks
Serial.println("Scanning available networks. May take some seconds.");
Serial.println(scannerNetworks.readNetworks());
// currently connected carrier
Serial.print("Current carrier: ");
Serial.println(scannerNetworks.getCurrentCarrier());
// returns strength and ber
// signal strength in 0-31 scale. 31 means power > 51dBm
// BER is the Bit Error Rate. 0-7 scale. 99=not detectable
Serial.print("Signal Strength: ");
Serial.print(scannerNetworks.getSignalStrength());
Serial.println(" [0-31]");
It took me 6h find it out that all, I hope that this will help someone ![]()
ps: I registered here to write this message, if the admin finds it necessary, he can delete this topic
And sorry for my bad english if you do not understand something I can try to clarify the point as long as I have time.
