Help for count an optocuplor on arduino
Hello everyone.
Excuse my english.
I need some help.
I want to count an optocuplor in a period of time.
I have this one:
ebay.com/itm/271056595842?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I connected it on an analog pin and send result on serial.Into photocelule i roate an object with an hole on it but the result on my serial is wrong.
If i roatate twice i think i must a result on my serial 2 but the result is 34 or 36 or otherelese.
Please give me your help.
Many thanks to all.
To give meaningful help we need instructions on how the device is/should be connected to arduino. The image just shows VCC,GND & OUT but is it a digital/analogue output, does it need pullup/pulldown resistors.
Maybe a picture of the way your shaft encoder looks. How many fins on the encoder wheel?
A description of how you have the device connected and your sample code (posted using the code (#) tags).
Hi and thanks for yout answer.
I'm not an electronist.
I think it is an analog sensor not a digital one , because if i connect it to a digital pin it doesn't send anything.If i connect on an analog pin it send some value, if it doesn't have any object into optocuplor it send me a 36 alternate 37 values. if i put something into optocuplor it send me values greate than 100.
My code is a simple cod for read an analog pin, because first i want to know what sensor send and after this i need to count it:
int sensorPin = A8;
int sensorValue = 0;
pinMode(sensorPin , INPUT);
sensorValue = analogRead(sensorPin);
Serial.println(delay(sensorValue);
Many thanks.
There is a slight error in your code with missing ')' or spurious 'delay('. I don't think you need the delay for testing or it should be on separate line
    Serial.println(sensorValue);
You say it does not work using digital pin but did the pin stay high or low, ambient light can effect some of these types of sensor. Try it in a darkened room or cover with you hand to mask most of the light and try it. Do you need a pullup/pulldown/inlinee resistor on the out pin? Did you get any datasheet of connection instructions with the device?
Hi and thanks again.
The"delay" it is wrong "copy paste" from my program.
i don't have a datasheet but i contacted the seller and he told me it is a digital pin and it works directly with arduino.
So i think it must write on serial 0 or 1 depends of the state of the optocuplor. Is it correct or not?
Many many thanks again.
tao13:
At least we now know what type of signal to deal with. Looking at the board there appears to be 2 visible LED's. One marked power that I suspect is always on when power is applied (I assume your powering the board from the arduino). The other marked sensor I assume lights when the IR sensor beam is blocked or vice-versa. Connect the boards 'out' pin to pin 8 of your arduino and try the below code. When you block/unblock the sensor the value scrolling thru the serial monitor should hopefully change and the sensor LED should also go on/off.
int sensorPin = 8;
    pinMode(sensorPin , INPUT_PULLUP);
    sensorValue = digitalRead(sensorPin);
    delay(100);
Your application sounds like a digital application. Adcing it is doable but not as efficient as reading logic '1's and '0's.
Hi again to all.
This is ok right now.I see on serial 0 and 1.
Now I want to do a track with a slot to see if it can read engine speed but first i'll put on the machine holes.
Many many thanks.
