Help for Decoding SEA j1939 Using MCP2515 and Arduino Uno
I'm trying to Monitor My CAT machine's Engine Load, RPM, and Temperature.
It sends this data vis CAN BUS SEA j1939 standard I've used CanHacker to extract some information to take a peek at what happening on data lines
I was able to find this, My Question is how to Decode the hex data which is 8 DLC?
Current Code:
#include <can.h>
#include <mcp2515.h>
#include <CanHacker.h>
#include <CanHackerLineReader.h>
#include <lib.h>
#include <SPI.h>
#include <SoftwareSerial.h>
const int SPI_CS_PIN = 10;
const int INT_PIN = 2;
const int SS_RX_PIN = 3;
const int SS_TX_PIN = 4;
CanHackerLineReader *lineReader = NULL;
CanHacker *canHacker = NULL;
SoftwareSerial softwareSerial(SS_RX_PIN, SS_TX_PIN);
    while (!Serial);
    SPI.begin();
    softwareSerial.begin(115200);
    Stream *interfaceStream = &Serial;
    Stream *debugStream = &softwareSerial;
    canHacker = new CanHacker(interfaceStream, debugStream, SPI_CS_PIN);
    //canHacker->enableLoopback(); // uncomment this for loopback
    lineReader = new CanHackerLineReader(canHacker);
    pinMode(INT_PIN, INPUT);
    CanHacker::ERROR error;
    if (digitalRead(INT_PIN) == LOW) {
        error = canHacker->processInterrupt();
        handleError(error);
    error = lineReader->process();
    handleError(error);
void handleError(const CanHacker::ERROR error) {
    switch (error) {
        case CanHacker::ERROR_OK:
        case CanHacker::ERROR_UNKNOWN_COMMAND:
        case CanHacker::ERROR_NOT_CONNECTED:
        case CanHacker::ERROR_MCP2515_ERRIF:
        case CanHacker::ERROR_INVALID_COMMAND:
            return;
        default:
    softwareSerial.print("Failure (code ");
    softwareSerial.print((int)error);
    softwareSerial.println(")");
    digitalWrite(SPI_CS_PIN, HIGH);
    pinMode(LED_BUILTIN, OUTPUT);
    while (1) {
        int c = (int)error;
        for (int i=0; i<c; i++) {
            digitalWrite(LED_BUILTIN, HIGH);
            digitalWrite(LED_BUILTIN, LOW);
        delay(2000);
I moved your topic to an appropriate forum category @Kirtiraj.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Find the DBC file for your vehicle.
did you more simply try sending OBDII command to the Engine control Unit to see if you get a reply for rpm PID?
Thanks mate, Really Appreciate it.
Not trying to send commands to it The ECU sends this info to PLC I'm just trying to sniff the info.
I have a question. How did you wire it to the ECU? And when connecting your Arduino to the ECU did you had to do something before it started sending data or did it start send data without doing anything special?
