I am still a n00b at figuring out this sort of stuff... can anyone talk me through what sort of battery pack I'd need? I'm simply trying to run 108 of those LED's in series and have decent battery life. N00b-comprehensible explanations appreciated. :D
It depends if the PCB wires all the LEDs in serial or in parallel. I'd hope they'd wire it in parallel.
The PCB link you provided says the LEDs are wired in 2 different groups:
?2 different groups of LED with different forward voltages :
Red, Orange, Yellow (ROY) need 1.8V to 2.0V forward voltage
White, Blue, Green, UV (WBGU) need 3.0 to 3.3V forward voltage
?For ROY Group, apply 8VDC, total current for the Module is 540mA, power consumption about 5W
?For WBGU Group, apply 12VDC, total current for the Module is 540mA, power consumption about 7W
So it looks like you need a power supply (battery) that can provide 12V @ 1.08 Amps for however long you want the flashlight on.
what sort of batteries/resistors combination would provide that? I probably have a wall adapter that provides that, but it needs to be battery powered to be portable
I've got a wall adapter that I want to test this thing with... it's putting out 12V at 200mA. Is that enough to give this thing a try? I've got to think about what sort of batteries I can use to push this thing for a little while... I've got 2 remote control airplane batteries I should test
