help for making script ota
hi i want some help to make this script update ota i tried the example with no results .
can you help me - guide me through ? this is the original code
any help will be greatly appreciated
thanks in advance
chris
#include <SparkFunBME280.h>
#include <SparkFunCCS811.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define CCS811_ADDR 0x5B //Default I2C Address
//#define CCS811_ADDR 0x5A //Alternate I2C Address
#define PIN_NOT_WAKE 5
//Global sensor objects
CCS811 myCCS811(CCS811_ADDR);
BME280 myBME280;
// Connect to the WiFi
const char* ssid = "@@@@@@";
const char* password = "@@@@@!";
const char* mqtt_server = "192.168.1.177";
//covert to chart
    char cCo2[16];
    char cTvoc[16];
    char cTemp[16];
    char cPa[10];
    char cAlt[16];
    char cRh[16];
    char cInHg[16];
WiFiClient espClient;
PubSubClient client(espClient);
boolean reconnect() {// Loop until we're reconnected
  while (!client.connected()) {
    Serial.print (F("Contacting MQTT server..."));
    // Attempt to connect
    if (client.connect("group1","admin","@@@@@@")) {     //assign a "client name".  Each wemos must have a unique name
      Serial.println (F("connected"));
      // ... SUBSCRIBE TO TOPICS
      //      client.subscribe("Upstairs/Mbr/BME280/TempF");
      //      client.subscribe("Upstairs/Mbr/BME280/TempC");
      //      client.subscribe("Upstairs/Mbr/BME280/Humidity");
      //      client.subscribe("Upstairs/Mbr/BME280/Pressure");
      return client.connected();
      Serial.print (F("Failed to connect. "));
      Serial.println (F(" Attempting connection again in 3 seconds"));
      // Wait 3 seconds before retrying
      //      delay(3000);
      return 0;
void setup(){
    client.setServer(mqtt_server, 1883);
    // Connect to WiFinetwork
  Serial.print (F("Connecting to "));
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  WiFi.mode(WIFI_STA);
    //Serial.begin(9600);
    Serial.print (F("."));
  Serial.println (F(""));
  Serial.println (F("WiFi connected"));
  // Print the IP address
  Serial.print (F("Local IP: "));
{  Serial.println();
  Serial.println("Apply BME280 data to CCS811 for compensation.");
  //This begins the CCS811 sensor and prints error status of .begin()
  CCS811Core::status returnCode = myCCS811.begin();
  Serial.print("CCS811 begin exited with: ");
  //Pass the error code to a function to print the results
  printDriverError( returnCode );
  //For I2C, enable the following and disable the SPI section
  myBME280.settings.commInterface = I2C_MODE;
  myBME280.settings.I2CAddress = 0x77;
  //Initialize BME280
  myBME280.settings.runMode = 3; //Normal mode
  myBME280.settings.tStandby = 0;
  myBME280.settings.filter = 4;
  myBME280.settings.tempOverSample = 5;
  myBME280.settings.pressOverSample = 5;
  myBME280.settings.humidOverSample = 5;
  //Calling .begin() causes the settings to be loaded
  delay(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
  myBME280.begin();
void loop(){
  if (!client.connected()) {
    reconnect();
  //Check to see if data is available
  if (myCCS811.dataAvailable())
    //Calling this function updates the global tVOC and eCO2 variables
    myCCS811.readAlgorithmResults();
    //printInfoSerial fetches the values of tVOC and eCO2
    printInfoSerial();
    float BMEtempC = myBME280.readTempC();
    float BMEhumid = myBME280.readFloatHumidity();
    Serial.print("Applying new values (deg C, %): ");
    Serial.print(BMEtempC);
    Serial.print(",");
    Serial.println(BMEhumid);
    //This sends the temperature data to the CCS811
    myCCS811.setEnvironmentalData(BMEhumid, BMEtempC);
  else if (myCCS811.checkForStatusError())
    //If the CCS811 found an internal error, print it.
    printSensorError();
  delay(30000); //Wait for next reading
void printInfoSerial()
  //getCO2() gets the previously read data from the library
  int data= (myCCS811.getCO2());
  (itoa(data, cCo2, 10));
  Serial.println("CCS811 data:");
  Serial.print(" CO2 concentration : ");
  Serial.print(myCCS811.getCO2());
  Serial.println(" ppm");
  client.publish("enviroment/sensor/group1/CO2", cCo2);
  //getTVOC() gets the previously read data from the library
  int data1= (myCCS811.getTVOC());
  (itoa(data1, cTvoc, 10));
  Serial.print(" TVOC concentration : ");
  Serial.print(myCCS811.getTVOC());
  Serial.println(" ppb");
  client.publish("enviroment/sensor/group1/TVOC_ppb", cTvoc);
  float data2= (myBME280.readTempC());
  dtostrf(data2, 10, 2, cTemp);
  Serial.println("BME280 data:");
  Serial.print(" Temperature: ");
  Serial.print(myBME280.readTempC(), 2);
  Serial.println(" degrees C");
  client.publish("enviroment/sensor/group1/TempC", cTemp);
  float data3= (myBME280.readFloatPressure());
  dtostrf(data3, 10, 2, cPa);
  Serial.print(" Pressure: ");
  Serial.print(myBME280.readFloatPressure(), 2);
  Serial.println(" Pa");
  client.publish("enviroment/sensor/BME280/Pressure_Pa", cPa);
  float data4 = ((myBME280.readFloatPressure() * 0.0002953));
  dtostrf(data4, 10, 2, cInHg);
  Serial.print((myBME280.readFloatPressure() * 0.0002953), 2);
  Serial.println(" InHg");
  client.publish("enviroment/sensor/group1/Pressure_InHg", cInHg);
  float data5 = (myBME280.readFloatAltitudeMeters());
  dtostrf(data5, 10, 2, cAlt);
  Serial.print(" Altitude: ");
  Serial.print(myBME280.readFloatAltitudeMeters(), 2);
  Serial.println("m");
  client.publish("enviroment/sensor/group1/AltitudeMeters", cAlt);
  float data6 = (myBME280.readFloatHumidity());
  dtostrf(data6, 10, 2, cRh);
  Serial.print(" %RH: ");
  Serial.print(myBME280.readFloatHumidity(), 2);
  Serial.println(" %");
  client.publish("enviroment/sensor/group1/Humidity", cRh);
//printDriverError decodes the CCS811Core::status type and prints the
//type of error to the serial terminal.
//Save the return value of any function of type CCS811Core::status, then pass
//to this function to see what the output was.
void printDriverError( CCS811Core::status errorCode )
  switch ( errorCode )
    case CCS811Core::SENSOR_SUCCESS:
      Serial.print("SUCCESS");
    case CCS811Core::SENSOR_ID_ERROR:
      Serial.print("ID_ERROR");
    case CCS811Core::SENSOR_I2C_ERROR:
      Serial.print("I2C_ERROR");
    case CCS811Core::SENSOR_INTERNAL_ERROR:
      Serial.print("INTERNAL_ERROR");
    case CCS811Core::SENSOR_GENERIC_ERROR:
      Serial.print("GENERIC_ERROR");
    default:
      Serial.print("Unspecified error.");
//printSensorError gets, clears, then prints the errors
//saved within the error register.
void printSensorError()
  uint8_t error = myCCS811.getErrorRegister();
  if ( error == 0xFF ) //comm error
    Serial.println("Failed to get ERROR_ID register.");
    Serial.print("Error: ");
    if (error & 1 << 5) Serial.print("HeaterSupply");
    if (error & 1 << 4) Serial.print("HeaterFault");
    if (error & 1 << 3) Serial.print("MaxResistance");
    if (error & 1 << 2) Serial.print("MeasModeInvalid");
    if (error & 1 << 1) Serial.print("ReadRegInvalid");
    if (error & 1 << 0) Serial.print("MsgInvalid");
Full instructions on how to set up OTA with example code (and a lot more interesting information about how to deal with the ESP8266 processor) you can find in Pieter's starter guide. OTA is in chapter 10.
(deleted)
Oh... A ] got lost :slight_smile: Fixed.
