help for multiple sensors hook up to arduino
hello guys.
im newbie wid arduino
so, i want hook up both pir motion sensor and vibrating sensor to the arduino. along with 2 leds.
can anyone tell me how to connect the circuit? diagram of it.
do i need pc boards?
thanks you
do i need pc boards
No you should be able to wire it all directly.
However you don't say what vibration sensor or what pir sensor you are using. Without knowing this you can't find out what signals they give and so you don't know how you need to change those to wire them into an arduino.
Please post a link to the data sheets of those devices.
When you asked "Do I need PC boards", did you mean fancy things covered in electronic devices? If so- no, you don't.
If you haven't met them, PROTO- boards, aka breadboards, are great little things for doing one-off experiments...
http://wulfden.org/TheShoppe/accessories.shtml
Start the project you have sketched with set ups which use just one LED, one of your sensors. When you have each working correctly separately, then put them together in one project.
If you have trouble with either, it would be best to start a new thread about just that sensor and the "fun" you are having with it.
im using this
and this
