Help for newbie: Sequence runs once or twice then stops
So I'm very new to the Arduino but I've ben watching and reading a lot. My project needs a sequence of 4 chasing LEDs. I downloaded a code from someone and the sequence will run 1 or 2 times then stop. If i touch the power cord or lift the Arduino and place it back down, the program runs again. The Arduino never seems to lose power since the green LED on it never turns off. The original program was for a setup with a motion sensor but im not using a motion sensor. I'll post the code to see if maybe its a line or two that need to be removed. I appreciate any help.
Here's the code:
  • PIR sensor tester
int ledPin = 13; // choose the pin for the LED
int inputPin = 2; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int ledPin1 = 9;
int ledPin2 = 6;
int ledPin3 = 5;
int ledPin4 = 3;
int surroundPin = 11;
int fadespeed = 10;
int timeTravelSpeed = 80;
int timeTravelLength = 25;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
//Serial.begin(9600);
void loop(){
val = digitalRead(inputPin); // read input value
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
runlights(); //run the light show!
if (pirState == LOW) {
// we have just turned on
//Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
//Serial.println("Motion ended!");
pirState = LOW;
void runlights(){
//Speed up loops
for (int fadeIncrement = 20; fadeIncrement <=100; fadeIncrement +=2){
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=fadeIncrement) {
analogWrite(ledPin1, fadeValue);
delay(fadespeed);
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=fadeIncrement) {
delay(fadespeed);
analogWrite(ledPin1, 0);
analogWrite(ledPin2, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin2, 0);
analogWrite(ledPin3, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin3, 0);
analogWrite(ledPin4, fadeValue);
delay(fadespeed);
delay(fadespeed);
analogWrite(ledPin4, 0);
//time travel loops
for (int timetravel = 1; timetravel <=timeTravelLength; timetravel +=1){
//turn on surround lights
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=15) {
analogWrite(surroundPin, fadeValue);
delay(fadespeed);
//Run time travel lights
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=timeTravelSpeed) {
delay(fadespeed);
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=timeTravelSpeed) {
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
delay(fadespeed);
//fade out the surround lights
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=15) {
delay(fadespeed);
You should post code using code tags like this:
void loop(){
If you are not using a PIR sensor, what is connected to inputPin? If there is nothing, the input will float around aimlessly - this could be why it is sensitive to being handled. If you have a switch connected, and use
pinMode(inputPin, INPUT_PULLUP);     // declare sensor as input, pulled high (switch will pull it low)
then you may get better results
